JamieB Member 58 Member For: 11y 7m 23d Posted 27/07/15 12:18 PM Share Posted 27/07/15 12:18 PM hi,just bought and installed a set of xyz coilovers in my fg xr6t sedan.I have set the car to the height I want just a little confused on how to correctly set the rear shocks.it says to set the height I want with the spring and adjust the shock so the spring is nor compressed or loose, drive around the block then adjust the shock rod so it is 1/3 into the shock body with the car on the ground.how am I meant to adjust or measure the shock rod with the car on the ground?separate_spring_shock_instructions.pdf Link to comment Share on other sites More sharing options...
RegSpec Cruise Control 1,417 Member For: 18y 2m 8d Gender: Male Location: Macksville NSW. Posted 27/07/15 12:34 PM Share Posted 27/07/15 12:34 PM Good question actually..... From what I've been told, you need to reset the wheel alignment whenever you fit/alter the ride height on coilovers.....So being the slacker that I am I usually drop the car off with instructions on how high I want it and let the pros set it up for me..... Comes back perfect every time mate..... Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 14d Gender: Male Location: Perth Posted 27/07/15 12:34 PM Share Posted 27/07/15 12:34 PM Skinny arms.Or put it on a 4 post hoist and do it, or jack up the car, remove the wheels, jack the lower control arm until you take the weight of the car and then adjust the shock.I set my rears by measuring the shock mount bolt centre to bolt centre with a tape measure then measuring the compressed and extended length of the shock, apply some maths and you will get the shock lengthTake the difference between the compressed and extended length and times it by .33 then add this to the compressed length this will give you the shock length when installed (which should be pretty close the bolt centre to bolt centre measurement for the shock mounts on the car) Link to comment Share on other sites More sharing options...
