  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 10d
Turbosmart actuators are an art to set up
Done many of them but it's miles away from a traditional actuator ;)
To reduce the B/S use a genuine adjustable Garrett 11.9psi actuator from MTQ set up like a normal one ( 1/2 hole pre load )
  • Bronze Donating Members
  • Member For: 12y 1m 4d
The garrett 11.8 will have a sticker on it and the P.N. will end with a 7 and half hole is what I set mine at
Edited by BenDoCo
  • Member For: 14y 2m
Got the actuator off part number ended in -17 and had another one that ended in -7, both Garrett items.... On my bench they both opened at 15psi but the -17 was far smoother and had a much longer stroke, the spare -7 I had kind of didn't creep just sprung out suddenly like it was sticky and then didn't really open much
So I put the -17 back on
Adjusted the pac performance "bolt on" bracket for a more direct action - was also there -7 actuator that was rubbish
Then got some guidance from the legend that is wombat bellend and made the port on the housing even larger and smoothed out all the inner radius, stripped another exhaust stud once everything was together on retorque
Pulled it all back off - sump to oil return gasket tore
Ford had just closed
Autobahnzzz, super cheap and repco and auto one spare parts people all looking at me like an alien when asking for the gasket I needed
Bought some gasket paper and made my own
Heli coil in the head
Put together
Drove to autobahn
Bought sausage at sausage sizzle
Bought boost gauge
Installed in car park aka hose from engine bay through bonnet, routed through window into cab and gauge sitting in lap
200km /h in 4th on private road boost gauge in one hand
No over boosting
Thank you bellend
Dyno tomorrow
  • Like 3
