frozenxr6t Member 140 Member For: 10y 8m 26d Posted 08/08/15 09:35 AM Share Posted 08/08/15 09:35 AM and news on the new setup Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/7/#findComment-1557088 Share on other sites More sharing options...
747pwr Member 68 Member For: 14y 1m 29d Gender: Male Posted 08/08/15 02:01 PM Author Share Posted 08/08/15 02:01 PM I work away so nothing happening this week- get back mid week and will be picking up new housing and turbo to assemble and put it all back together - hopefully tuned before the weekend Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/7/#findComment-1557105 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 11m 29d Gender: Male Location: Gold Coast Posted 11/08/15 09:03 AM Share Posted 11/08/15 09:03 AM I couldn't get mine to make less than 18psi Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/7/#findComment-1557490 Share on other sites More sharing options...
747pwr Member 68 Member For: 14y 1m 29d Gender: Male Posted 12/08/15 11:14 AM Author Share Posted 12/08/15 11:14 AM (edited) That's common if your port job is dodgyFitted the new set up today - hopefully tuned tomorrow or Friday Edited 12/08/15 11:22 AM by 747pwr 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/7/#findComment-1557643 Share on other sites More sharing options...
747pwr Member 68 Member For: 14y 1m 29d Gender: Male Posted 13/08/15 03:20 AM Author Share Posted 13/08/15 03:20 AM Picture of the bay yesterday after installing the gtx3582 dropped it off for a tune this morning on 98.Initial thoughts - this thing is quiet and wasn't feeling much torque under 3000rpm - mind you was only cruising to the workshop. Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/7/#findComment-1557732 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 9d Gender: Male Location: Adelaide Posted 13/08/15 03:43 AM Share Posted 13/08/15 03:43 AM Mate the 76 and 82 are a noticeable step apartWe did try to tell you 2 Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/7/#findComment-1557737 Share on other sites More sharing options...
747pwr Member 68 Member For: 14y 1m 29d Gender: Male Posted 13/08/15 03:47 AM Author Share Posted 13/08/15 03:47 AM Yeah I'm not saying it's bad - I wanted the power to shift higher In the revs, the 76 fell over to early for MY liking Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/7/#findComment-1557738 Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 12y 1m 3d Gender: Male Location: A big bridge over a river in South Australia Posted 13/08/15 04:15 AM Share Posted 13/08/15 04:15 AM Ya shoulda told ya tuna to fix it then but no matter now as I see that some very lucky person now has a 76.Congrats - whoever bought it Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/7/#findComment-1557740 Share on other sites More sharing options...
747pwr Member 68 Member For: 14y 1m 29d Gender: Male Posted 13/08/15 04:54 AM Author Share Posted 13/08/15 04:54 AM Wasn't the tuners fault - last tuning session cut short due to a boost issue/mechanical problem so tuned best we could - got bored one day and started this thread - got some good advice and found the problem, always wanted the bigger turbo and once the 76 sold the swap cost me a couple hundred plus the tune, car was apart and had to retune anyway was kind of two birds one stone. Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/7/#findComment-1557745 Share on other sites More sharing options...
747pwr Member 68 Member For: 14y 1m 29d Gender: Male Posted 14/08/15 11:04 AM Author Share Posted 14/08/15 11:04 AM Was on dyno today briefly, under boosting sorted, now over boosting issue with new turbo/housing/wastegateDialed in 17psi would make it until 3800 then 20psi by 5000 till red lineI bench tested the actuator would open at 15psi on any preload setting, I set the preload to about 3mm used to compressor to push rod onto waste gate, which was the least preload to make the valve not spin on the housing when I tried. Could still move the actuator rod by hand if hanging off it, way easier than the turbo smart set upBut I read they use much less preload than the turbo smart part.The flapper valve is a 38mm item and we ported it slightly smaller than previous housing to try keep some more meat to prevent cracking this one.Does it sound like I set the actuator up right ? Good chance I'll have to pull off housing and open port up some more ? It was d-shaped like shown on here.Guess I'll be in shed all weekend But it did make 400rwkw on 98, reduced timing 17psi building to 20. Which is a start haha Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/7/#findComment-1557977 Share on other sites More sharing options...
