Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 14d Gender: Male Posted 26/07/15 10:25 AM Share Posted 26/07/15 10:25 AM When you say you guys run 20 or more are you referring to midrange boost or boost at peak power?I didn't think the GTX3576 could blow well into the 20s at higher revs/peak power? Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/2/#findComment-1555568 Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 12y 1m 1d Gender: Male Location: A big bridge over a river in South Australia Posted 26/07/15 10:30 AM Share Posted 26/07/15 10:30 AM (edited) I've still got 19 at about 5200 'ish and then it drops away skiddyEditcan't find it atm but I read somewhere (I THINK it was on the garret site) that the ..76 is most efficient at 20 to 22 psi Edited 26/07/15 10:31 AM by BenDoCo 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/2/#findComment-1555569 Share on other sites More sharing options...
747pwr Member 68 Member For: 14y 1m 27d Gender: Male Posted 26/07/15 08:27 PM Author Share Posted 26/07/15 08:27 PM On 26/07/2015 at 10:30 AM, BenDoCo said: I've still got 19 at about 5200 'ish and then it drops away skiddyEditcan't find it atm but I read somewhere (I THINK it was on the garret site) that the ..76 is most efficient at 20 to 22 psiThat sounds similiar to how mine is behaving, 18 till about 5000 then drops. Its the second one the workshop I have used has done with gtx3576 - it cant push over 500rwhp with near identical parts spec but manual - our dyno does read low, When "big cars" from other workshops run on it they regulary show lower power figures- so I wouldnt be suprised if it is making more than 470rwhp but we cannot get it to make any more boost than 18psi, tried asking for 30psi, tried different actuator tensions, ran it with the gate closed, ran it on just the 4inch dump pipe, its got a plaz 4inch race intake so left that in place. Any suggestions for things to try would be great but I think we have covered everything Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/2/#findComment-1555607 Share on other sites More sharing options...
PAH Donating Members 361 Member For: 16y 3m 19d Gender: Male Posted 26/07/15 10:38 PM Share Posted 26/07/15 10:38 PM Guys. Not sure how much boost I am running with my GTX3576 but it's making just under 360kw at the wheels with a new Zorst and PW stepped cooler. Comparing the dyno charts (factory turbo to GTX3576) I've lost a bit of mid range torque with the GTX3576 and I guess that's to be expected. I think that the GTX3576 is a good turbo for street use. I doubt that I'd fit a GTX3582 to a street car. I remember reading a post that said that the GTX3576 smokes the GTX3582 on the track too. By the time the GTX3582 comes on boost, he's at the next apex. It was that post that pushed me towards the GTX3576.PAH 2 Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/2/#findComment-1555616 Share on other sites More sharing options...
747pwr Member 68 Member For: 14y 1m 27d Gender: Male Posted 26/07/15 10:53 PM Author Share Posted 26/07/15 10:53 PM PAH, thanks for posting- can I ask what outcome you asked your tuner for ? Did you want 360ish or asked them to tune it for everything it was capable of ? Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/2/#findComment-1555619 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 5m 18d Gender: Male Location: Brisbane Posted 27/07/15 12:47 AM Share Posted 27/07/15 12:47 AM PAH I really don't see how you could have lost midrange over the standard 76...what's the tune like? Have you got a sheet that shows the boost curve? Sorry if you have already posted it. The little gtx in hard and fast should basically be...well a useless tyre fryer lol. If set up right from what other peeps who have one have said its better everywhere? Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/2/#findComment-1555627 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 8m 4d Gender: Male Location: Townsville Posted 27/07/15 03:46 AM Share Posted 27/07/15 03:46 AM I still find it strange that you can't get over 18psi regardless in the mid rpm range? If you are then I would say ok but if you aren't then I believe there is a bigger problem as holding the gate shut is boost heaven (with potential grenade status) and should easily see 20+ unless the ported housing is rooted? Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/2/#findComment-1555640 Share on other sites More sharing options...
747pwr Member 68 Member For: 14y 1m 27d Gender: Male Posted 27/07/15 03:57 AM Author Share Posted 27/07/15 03:57 AM I agree that the 76 is better all over the standard turbo, it just lacks top end for me which is why im thinking of simply swapping the cores and hoping the gtx3582 produces the tyre carnage I'm after but it will enter gearbox and motor danger zone for sure. Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/2/#findComment-1555642 Share on other sites More sharing options...
747pwr Member 68 Member For: 14y 1m 27d Gender: Male Posted 27/07/15 04:02 AM Author Share Posted 27/07/15 04:02 AM On 27/07/2015 at 3:46 AM, bjc said: I still find it strange that you can't get over 18psi regardless in the mid rpm range? If you are then I would say ok but if you aren't then I believe there is a bigger problem as holding the gate shut is boost heaven (with potential grenade status) and should easily see 20+ unless the ported housing is rooted?When I said we held the gate shut that was only on the dyno for testing purposes, honestly we have tried different pressure springs in the turbosmart actuator, exhaust dropped, disconnected signal line to actuator, different actuator, commanding maxiumum possible boost, nothing can make it produce anything more than 18psi or 16psi at the peak. The housing was used on another vehicle and they actually had trouble keeping the boost from going too high until the porting that is still current, was done. Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/2/#findComment-1555643 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 8m 4d Gender: Male Location: Townsville Posted 27/07/15 04:48 AM Share Posted 27/07/15 04:48 AM Not knocking you mate as I did this (steel wired the wastegate shut) while testing a friends FG on the street as it simply wasn't coming onto boost until 4500rpm with it even wired shut which meant to me that the wastegate porting was fcked which it was! So you are saying that you couldn't make over 20psi with your combo, then put the turbo on a different car and had no low boost problems to which they fitted a ported housing to the second car then boost was under control and then that complete turbo with new ported housing was fitted back to your car? If that all is a yes then the problem lies with your car somewhere and not the turbo... Is be checking for boost leaks from turbo all the way to the intake manifold to head and also exhaust housing leaks! Link to comment https://www.fordxr6turbo.com/forum/topic/90901-swapping-from-gtx3576-to-gtx3582/page/2/#findComment-1555657 Share on other sites More sharing options...
