Lennox Member 2,586 Member For: 12y 2m 20d Gender: Male Location: Perth Posted 22/07/15 12:03 AM Share Posted 22/07/15 12:03 AM Yeh but sometimes they push what they make most money on not necessarily what you need for your specific goals.... 4 Link to comment https://www.fordxr6turbo.com/forum/topic/90878-e85-set-up/page/2/#findComment-1554940 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 15d Gender: Male Location: Western Sydney Posted 22/07/15 12:18 AM Share Posted 22/07/15 12:18 AM On 21/07/2015 at 8:55 PM, Silverfox666 said: Ok so if I go a PW duel pump surge and a reg fitting kit to my standard rail and a DW200 in the tank than that will be suitable to get the E85 tune ?????You'll need more than a standard rail if your going twin pumps for that power level. Will probably need the billet rail with a -10 return to the surge and an fpr2000 reg. Link to comment https://www.fordxr6turbo.com/forum/topic/90878-e85-set-up/page/2/#findComment-1554947 Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 23d Gender: Male Posted 22/07/15 12:34 AM Share Posted 22/07/15 12:34 AM The Process West twin pump kit struggles to get base pressure to 58.5psi at idle....I know if a few that have the reg adjusted to the minimum but still see low 60s psi wise at idle.The best way to fix this is fit a -8 return to the main tank and modify the cradle to accept the -8 braided line so its a true -8 return all the way not bottlenecks.Rail wise you will get away using the stock one this way but going to the Plazmaman item is hard to ignore with its easy fitment/removal compared to some others.As mentioned consulting tuner is the fool proof way but also as mentioned they sometimes push what gets more mark up for them not what may actually suffice. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90878-e85-set-up/page/2/#findComment-1554954 Share on other sites More sharing options...
eff xr6t Member 569 Member For: 11y 7m 17d Posted 22/07/15 01:15 AM Share Posted 22/07/15 01:15 AM Fark paying for a billet fuel rail go buy two weld on -8 fittings cost $5 each chop the two ends of the rail off and get someone to tig the fittings on shouldn't take more then 10 mins to weld then you just saved yourself $400 on a pos billet rail that doesn't even fit anyway. Use the money saved to run full Teflon lines. Link to comment https://www.fordxr6turbo.com/forum/topic/90878-e85-set-up/page/2/#findComment-1554961 Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 5m 22d Gender: Male Location: Perth Posted 22/07/15 01:17 AM Share Posted 22/07/15 01:17 AM I've never had an issue with my PW dual feed rail 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90878-e85-set-up/page/2/#findComment-1554962 Share on other sites More sharing options...
KPM Motorsport Member 968 Member For: 19y 6m 24d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 22/07/15 01:26 AM Share Posted 22/07/15 01:26 AM (edited) Streetfighter have complete no fuss correctly engineered packages to suit your power level.Single Walbro 460 intank SystemStreetfighter 1000hp Intank SystemStreetfighter 1500hp Intank SystemThis completely eliminates surge tanks.Many workshops now are realizing the benefits and higher horsepower potentialQuietNo smellsLegalNo Fuss / Fit and forgetAll include direct fit in tank pump systemsDirect fit High Flow fuel pressure regulator systemsCorrect plug and play wiring and relay optional:1500hp fuel filters550/1000/1500/1700 cc InjectorsThis kits are engineered to fit and wotk as advertised without any fuss. All components are 100% E85 / E100 / Ethanol compatible.No wasted money on unneeded parts or patch ups. Just fit and forget. Edited 22/07/15 01:54 AM by KPM Motorsport 2 Link to comment https://www.fordxr6turbo.com/forum/topic/90878-e85-set-up/page/2/#findComment-1554966 Share on other sites More sharing options...
Silverfox666 Member 117 Member For: 10y 4m 20d Gender: Male Location: Sydney penrith Posted 22/07/15 01:54 AM Author Share Posted 22/07/15 01:54 AM Ok please PM me prices KPM MORORSPORTS Link to comment https://www.fordxr6turbo.com/forum/topic/90878-e85-set-up/page/2/#findComment-1554970 Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 23d Gender: Male Posted 22/07/15 02:46 AM Share Posted 22/07/15 02:46 AM Didn't think brass was e85 compatible is yours coated KPM or something?The Plaz surge tanks with the brass elbow on E85 the inside slowly eats away. Link to comment https://www.fordxr6turbo.com/forum/topic/90878-e85-set-up/page/2/#findComment-1554983 Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 11y 11m 21d Gender: Male Location: NOR Perth Posted 22/07/15 04:14 AM Share Posted 22/07/15 04:14 AM On 22/07/2015 at 1:54 AM, Silverfox666 said: Ok please PM me prices KPM MORORSPORTSExpensive....its on their website https://www.kpmauto.com/tabid/353/Default.aspxExcept no mention of 1500hp unit price? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90878-e85-set-up/page/2/#findComment-1554998 Share on other sites More sharing options...
KPM Motorsport Member 968 Member For: 19y 6m 24d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 22/07/15 11:48 PM Share Posted 22/07/15 11:48 PM On 22/07/2015 at 2:46 AM, Skids4kids said: Didn't think brass was e85 compatible is yours coated KPM or something?The Plaz surge tanks with the brass elbow on E85 the inside slowly eats away.Our fittings are all nickel plated and 100% E85 compatible. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/90878-e85-set-up/page/2/#findComment-1555143 Share on other sites More sharing options...
