04LTRB Member 319 Member For: 12y 4m 20d Posted 17/07/15 05:06 AM Share Posted 17/07/15 05:06 AM When I first drive my car in the morning turbo spools up an makes a really weird noise similar to a grinding noise at first I thought it was a big exhaust leak but then once I drive it for awhile the spooling noise seems to go away an sounds normal again What could the problem be I'm thinking of putting an inline oil filter to the turbo an c if anything changes its got me stumped All the bolts from turbo tomanifold are tight All the bolts from manifold to block are tight I looked an notice there's a bracket that goes from dumpipe to block it's missing the bolt at the dumpipe end could this be an issue at all Any help much appreciated Cheers Michael Link to comment Share on other sites More sharing options...
hrick Member 210 Member For: 15y 2m 27d Posted 17/07/15 07:43 AM Share Posted 17/07/15 07:43 AM (edited) I had what maybe sounds like a similar noise (thought a heat shield might have been loose, bit of a noise a 1600-1750 rpm), gradually got worse, stupid forkin standard turbo line filter/screen was starting to clog up, ended getting way noisy and needed a new turbo core in the end (the turbo was gradually being starved of oil). Preventative maintenance is always better. Edited 17/07/15 07:45 AM by hrick Link to comment Share on other sites More sharing options...
04LTRB Member 319 Member For: 12y 4m 20d Posted 17/07/15 08:11 AM Author Share Posted 17/07/15 08:11 AM Yea I'm Gunns get an oil filter for sure now before its to late Link to comment Share on other sites More sharing options...
julesk_1972 Member 267 Member For: 12y 7m 17d Gender: Male Location: Perth Posted 17/07/15 09:09 AM Share Posted 17/07/15 09:09 AM Remove line screen completely..Problem solved. Link to comment Share on other sites More sharing options...
hrick Member 210 Member For: 15y 2m 27d Posted 17/07/15 11:34 AM Share Posted 17/07/15 11:34 AM (edited) Yea I'm Gunns get an oil filter for sure now before its to latehope its not too late if you already have a grinding (metal?) noise. Edited 17/07/15 11:35 AM by hrick Link to comment Share on other sites More sharing options...
04LTRB Member 319 Member For: 12y 4m 20d Posted 17/07/15 11:46 AM Author Share Posted 17/07/15 11:46 AM It goes away after about 4-5minutea of driving Link to comment Share on other sites More sharing options...
hrick Member 210 Member For: 15y 2m 27d Posted 17/07/15 10:50 PM Share Posted 17/07/15 10:50 PM It goes away after about 4-5minutea of drivingso did mine Link to comment Share on other sites More sharing options...
Swindog Member 40 Member For: 11y 7m 7d Posted 18/07/15 08:38 AM Share Posted 18/07/15 08:38 AM Pop the front turbo hose off. Put your finger on the nut holding the front wheel. Try and lift the wheel up and down or try and push it back. If it moves more than half a mm youll have done a bearing.Its a quick check and free.The odd noise you hear is prob the fact your thrust bearing is rooted.The oil filter screen is a common prob in Subarus too. Removing them and adding a larger braided line is the best long term solution but if you are hearing noises now it might be too late, especially if its combined with excessive wheel movement on your check. Check for fin damage or wear. Also signs that the bearings are wearing and the fins some times wear on the compressor housing, normally associated with high pitch squealing from the turbo on full torque.I speak from experience. A very costly experience Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 1m 3d Gender: Male Location: SW Sydney Posted 18/07/15 12:41 PM Share Posted 18/07/15 12:41 PM The oil filter screen is a common prob in Subarus too. So it's not only ford who fit an inline filter screen to the turbo oil supply line? Link to comment Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 11y 9m 17d Gender: Male Location: NOR Perth Posted 18/07/15 01:35 PM Share Posted 18/07/15 01:35 PM If it moves more than half a mm youll have done a bearing.I thought it was ok to move a little bit? All the adverts for used turbos must be wrong... I.e. when people say "slight movement" or "minimal" movement Link to comment Share on other sites More sharing options...
