Bigg_kayz Member 111 Member For: 10y 9m 15d Gender: Male Location: Perth, Northsider Posted 30/07/15 03:09 AM Author Share Posted 30/07/15 03:09 AM Come over, lets pull the tune and see what has been done. It is usually hard to determine fuel economy by numbers however based on what you have said it does seem to be using too much. The engine should operate on closed loop control so it should deliver OK economy regardless. However they could have butched things that kill economy.Is it still stalling?. I assume you are using bp98Yeah mate, always run bp98 even when on standard tune ... no more stalling it had 2 hiccups when I got it back , I think it was the last of the sh*t clearing itself out.where you located mate?could it be a bad 02 sensor throwing the fuel off? I never considered the thermostat, how could that be linked, just curious? Link to comment https://www.fordxr6turbo.com/forum/topic/90813-337l100kms-everyday-driving/page/5/#findComment-1555985 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 3m 1d Gender: Male Posted 30/07/15 06:16 AM Share Posted 30/07/15 06:16 AM City Beach. Could be a bad 02 sensor, could be thermostat. If you had Hp Tuner, you could hook it up and observe both on the data logger to see if they are where they are meant to be. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90813-337l100kms-everyday-driving/page/5/#findComment-1556009 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 7m 11d Gender: Male Location: Brisbane Posted 30/07/15 06:56 AM Share Posted 30/07/15 06:56 AM (edited) Trips are long enough to get into operating temp. Where your temp sits would suggest you have a cooler thermostat. The tune should have been adjusted accordingly though. That temp would be within the warmup cycle on a stock tune for example, which means running rich. Give it time like you say to average out before taking it backI have explained how, but if you catch up with trana I'm sure he will explain how fueling is tied to ECT amongst other things. In a nutshell if you run a cooler thermostat the tune needs to be adjusted accordingly. Or your thermostat could be buggered and opening to soon, stuck open even. In either case if thermostat is infact the issue(may not be) the tuner is responsible. Either didn't adjust tune or somehow failed to notice it was farked. Unless of course it miraculously shat itself the moment you drove out.....If your temp sat at the usual level I wouldn't even suggest it.... Edited 30/07/15 06:57 AM by barnz Link to comment https://www.fordxr6turbo.com/forum/topic/90813-337l100kms-everyday-driving/page/5/#findComment-1556014 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 8d Gender: Male Location: Perth Posted 30/07/15 06:59 AM Share Posted 30/07/15 06:59 AM My money is still on ID1000's with Deka scaling. Thermostat issue aint going to turn a car the should use 14/5ltrs per 100 into a car that uses 10+ ltrs above that.OP just needs to get some data logs off it to work out what's going on. Link to comment https://www.fordxr6turbo.com/forum/topic/90813-337l100kms-everyday-driving/page/5/#findComment-1556016 Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 12y 2m 24d Gender: Male Location: A big bridge over a river in South Australia Posted 30/07/15 07:00 AM Share Posted 30/07/15 07:00 AM (edited) +1 for incorrect injector scalingOrPinched an o-ring on install? Edited 30/07/15 07:01 AM by BenDoCo Link to comment https://www.fordxr6turbo.com/forum/topic/90813-337l100kms-everyday-driving/page/5/#findComment-1556017 Share on other sites More sharing options...
Bigg_kayz Member 111 Member For: 10y 9m 15d Gender: Male Location: Perth, Northsider Posted 30/07/15 08:57 AM Author Share Posted 30/07/15 08:57 AM seems weird I take it on for a retune, they suggest new injector fitment then scale it to the old injectors?not impossible, but weird :s+1 for incorrect injector scalingOrPinched an o-ring on install?pinched o ring? where abouts you reckon? Link to comment https://www.fordxr6turbo.com/forum/topic/90813-337l100kms-everyday-driving/page/5/#findComment-1556041 Share on other sites More sharing options...
Bigg_kayz Member 111 Member For: 10y 9m 15d Gender: Male Location: Perth, Northsider Posted 30/07/15 08:57 AM Author Share Posted 30/07/15 08:57 AM City Beach. Could be a bad 02 sensor, could be thermostat. If you had Hp Tuner, you could hook it up and observe both on the data logger to see if they are where they are meant to be. if you have the software thatd be sweet, ralph was gonna give me a hand previously but I ended up taking it to the tuner Link to comment https://www.fordxr6turbo.com/forum/topic/90813-337l100kms-everyday-driving/page/5/#findComment-1556042 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 3m 1d Gender: Male Posted 30/07/15 09:47 AM Share Posted 30/07/15 09:47 AM either one of us, both of us or what ever. Usually it will stick out like a sore thumb, but not always. Link to comment https://www.fordxr6turbo.com/forum/topic/90813-337l100kms-everyday-driving/page/5/#findComment-1556044 Share on other sites More sharing options...
