  • Member For: 12y 7m 26d
Hi guys,
Bought a BF XR6T ZF Magnet ute on the weekend, 98k kms, Ego. Love it.
Had an FG XR6T ute a few years ago now and loved it, but thought I would save myself a good 8-10 grand by getting a BF (much more sensible while I am saving for a house!)
Couple of things:
Firstly, the car doesn’t seem to go like the FG. It won’t bust out in wheelspin when it hits boost like the FG did.
It has a strange ‘flapping’ sound when it’s under load (and boost) – mostly evident in 2nd gear when the boost is probably highest under load. It sounds airy, like it could be a boost leak?
I assume this has a lot to do with the power delivery. Everything else is sweet; idles fine, doesn’t misbehave or miss or anything.
Secondly, the LSD is not quite LSD. I tried a quick launch (maybe using a bit of brake… ahem!) and all it left was a horrible single pegger. I tried again a few minutes later and same deal. I was gutted! Is it common for these to get slack and only throw one wheel? Furthermore, if punting it on a right turn it will open up the inside wheel, but if I do the same thing turning left, it will kick out. Bizarre.
Cheers guys!
Will.
https://www.fordxr6turbo.com/forum/topic/90809-flappy-air-noise-under-load-lsd/
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 11d
Fg's have the small turbo that comes on faster and harder so that's why your fg used to light up
So what u have now is fairly std
The air noise could definitely be a loose pipe and not helping the power output
It's very common for utes to single wheel sooner than the sedan as the diff arrangement is completely different and has a very poor lsd unit from factory
So again fairly common
  • I'm getten too old for this s**t
  • Bronze Donating Members
  • Member For: 12y 1m 5d
Does Bruce have a better mechanic working for him yet?
