ratter Member 6,793 Member For: 18y 8m 22d Gender: Male Location: @ my laptop Posted 19/07/15 01:40 AM Share Posted 19/07/15 01:40 AM 350 is what the manufacturers were saying, we have seen a little more buy things start to work harder Link to comment Share on other sites More sharing options...
LV3LLA New Member 3 Member For: 9y 9m 30d Posted 22/07/15 12:01 AM Author Share Posted 22/07/15 12:01 AM How does the battery side airbox VS an underbattery intake make any difference? the pipe is about a foot longer but same size and same pod filter. is that really going to limit 50+ KW???? Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 2m Gender: Male Location: North West Hot Hell,VIC Posted 22/07/15 08:34 PM Share Posted 22/07/15 08:34 PM Thanks Mick,LV#LLA the restriction is where the pipe goes through under the headlight area. Link to comment Share on other sites More sharing options...
PAH Donating Members 361 Member For: 16y 30d Gender: Male Posted 26/07/15 10:52 PM Share Posted 26/07/15 10:52 PM LV3LLA,I bought a brand new GTX3576 turbo core for $1450 from MTQ and had it fitted to my existing FG XR6T housing. Your turbo has done 160k? MTQ in Melbourne is at 1 Westside Drive Laverton North. 03 8346 9888. MTQ in Sydney looked after me as a Forum Member. PAH Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 5m 14d Gender: Male Location: Townsville Posted 28/07/15 04:07 AM Share Posted 28/07/15 04:07 AM LV3LLA,I'm not being harsh here mate but it seems the car will be a dyno queen and to you it's about the number and nothing else so IMO I would be going the route that takes you there the easiest and cheapest and in that case I would recommend a .70 comp housing to the mix with the 4in intake and forget the GTX's as they are expensive in comparison! Yes it will be lag central everywhere else but 400 right?Have you owned or been in a manual turbo ford with 350+rwkw to give you an idea of what's in store? The torque figure is what's the fun factor with these cars especially when it's ramped in hard... If your tuner is good and you drive like a normal person with the odd raping here and there (no rev limiter bouncing) then I can't see why the engine won't live a healthy ish long life on 20+psi. Hell my BA turbo is hopefully still having fun at 20psi with it's new owner and that's been doing that for a while now...Also, I'd add some very grippy decent 275 wide tyres to the mix if you want any traction at all as you're going to need it!!! Have fun... Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 3m 22d Gender: Male Location: Perth Posted 28/07/15 07:24 AM Share Posted 28/07/15 07:24 AM Sounds like your on a budget. Maybe rethink to 350rwkw. To push over 400 on 98 needs large intake ,cooler and exhaust. The bigger the better. 160ks is a bit to start modding to high power. And being a manual really requires billet oil pump gears Link to comment Share on other sites More sharing options...
Forbzy89 New Member 14 Member For: 9y 6m 14d Gender: Male Location: Adelaide Posted 20/10/15 06:27 PM Share Posted 20/10/15 06:27 PM hi there im running a bf tornado motor pump injectors dump full system and a bigger cooler standard piping 340rwkws running a single plate clutch but I would prob go bigger if u plan to drag alot ect Link to comment Share on other sites More sharing options...
sprouly07 Donating Members 62 Member For: 10y 7m 5d Gender: Male Location: Townsville Posted 28/12/15 06:57 AM Share Posted 28/12/15 06:57 AM Is there a reason you want 400kw? I've had my car running 350kw in my 6 speed manual for the past 9 months and its more than enough power for the street. infact alot people that I've actually spoken to suggest that 350kw is about the most you want for a street car. I've just recently put a gtx3582r on because the stock turbo failed and it was retuned and made 399.5kw on 98 but clutch was slipping so its now back to 360kw and that's with the stock exhaust, 1000cc injectors, valve springs, billet oil pump gears, plazmaman intercooler, cold side piping, custom intake, walbro 460 pump. So if you want 400kw I think it would make it, just depends on the tuner I guess.Like someone else said as well triple plate is probably a bit of an overkill. Link to comment Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 8m 24d Gender: Male Location: Central Queensland Posted 28/12/15 11:39 PM Share Posted 28/12/15 11:39 PM Anything is achievable, if you have the budget for it. There are plenty of cars in the 400+ section that you use as a guide for what is required to achieve the desired results. All in all, don't skimp on components, you do get what you pay for.. 1 Link to comment Share on other sites More sharing options...
