timwds Member 54 Member For: 13y 3m 13d Gender: Male Location: Tamworth Posted 03/07/15 04:00 AM Share Posted 03/07/15 04:00 AM Check your intake manifold bolts and try spaying some water around the gasket whiles it's running to check for leaks. Link to comment https://www.fordxr6turbo.com/forum/topic/90748-rough-idle/page/2/#findComment-1551566 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 4m 15d Gender: Male Posted 08/07/15 07:36 AM Share Posted 08/07/15 07:36 AM I have a miss at idle only when in D and gets worse when AC is on, in Neutral is mostly fine.Hoping to eliminate it, I've just done:engine mounts (stuffed anyway)spark plugs (genuine, and probably didn't need doing but probably halfway through their life)coils (genuine, and needed doing anyway)TB cleanI'm going to try the water trick around the intake manifold gasket.Its annoying. Link to comment https://www.fordxr6turbo.com/forum/topic/90748-rough-idle/page/2/#findComment-1552479 Share on other sites More sharing options...
timwds Member 54 Member For: 13y 3m 13d Gender: Male Location: Tamworth Posted 09/07/15 11:36 PM Share Posted 09/07/15 11:36 PM A manifold leak will normally get better with load because the vacuum is reduced. Roughness that gets increasing worse with load suggests either a spark or fueling issue. You could also try dumping bottle of nulon injector cleaner in a full tank of fuel, it has worked wonders in the past. I haven't had injector issues with Falcons before but have with many smaller cars (corolla etc), worth a shot if nothing else works. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90748-rough-idle/page/2/#findComment-1552813 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 8d Gender: Male Location: Perth Posted 10/07/15 12:07 AM Share Posted 10/07/15 12:07 AM On 08/07/2015 at 7:36 AM, SuckSqueezeBangBlow said: I have a miss at idle only when in D and gets worse when AC is on, in Neutral is mostly fine.Hoping to eliminate it, I've just done:engine mounts (stuffed anyway)spark plugs (genuine, and probably didn't need doing but probably halfway through their life)coils (genuine, and needed doing anyway)TB cleanI'm going to try the water trick around the intake manifold gasket.Its annoying.Is your car tuned/modded? Link to comment https://www.fordxr6turbo.com/forum/topic/90748-rough-idle/page/2/#findComment-1552823 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 4m 15d Gender: Male Posted 10/07/15 07:43 AM Share Posted 10/07/15 07:43 AM yes autotech tuned 280rwkw. bosch 968s, cat, 12psi Link to comment https://www.fordxr6turbo.com/forum/topic/90748-rough-idle/page/2/#findComment-1552956 Share on other sites More sharing options...
