Nugget New Member 8 Member For: 9y 10m 25d Posted 25/06/15 08:12 AM Share Posted 25/06/15 08:12 AM Hi Guy, My BA falcon has a rough idle, any suggestions or ideas on what it might be? Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/90748-rough-idle/ Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 11y 11m 10d Gender: Male Location: NOR Perth Posted 25/06/15 08:31 AM Share Posted 25/06/15 08:31 AM One I can sort of answer....from my limited reading:CoilsSpark PlugsDirty Throttle BodyThrottle Position Sensor (guess)Dirty injectors (another guess) Link to comment https://www.fordxr6turbo.com/forum/topic/90748-rough-idle/#findComment-1550257 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 9m Gender: Male Location: Adelaide Posted 25/06/15 08:38 AM Share Posted 25/06/15 08:38 AM Mines running rough. Poping quietly at idle and not running smoothly. How do you know if the coils are farked. Link to comment https://www.fordxr6turbo.com/forum/topic/90748-rough-idle/#findComment-1550259 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 3m 18d Gender: Male Location: Christchurch, New Zealand Posted 26/06/15 05:06 AM Share Posted 26/06/15 05:06 AM Coils will normally show by breaking down under load. Say 4th gear going full throttle and it will be fine until the RPM starts to get up a bit then usually a power loss/shuddering feeling. Link to comment https://www.fordxr6turbo.com/forum/topic/90748-rough-idle/#findComment-1550368 Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 11m 17d Posted 26/06/15 05:11 AM Share Posted 26/06/15 05:11 AM Could also be engine mounts...being a BA...your turbo side engine mount should be fried by now...(unless it has been changed already...) 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90748-rough-idle/#findComment-1550371 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 13d Gender: Male Location: Perth Posted 26/06/15 05:14 AM Share Posted 26/06/15 05:14 AM "rough idle" is a bit like "brake shudder" can occur for multiple reasons and an Idle miss is not the same as vibration from a cooked engine mount causing NVH transmission. Both can be described as a rough idle.OP are you able to pull codes from the car? Link to comment https://www.fordxr6turbo.com/forum/topic/90748-rough-idle/#findComment-1550373 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 9m Gender: Male Location: Adelaide Posted 26/06/15 05:40 AM Share Posted 26/06/15 05:40 AM On 26/06/2015 at 5:06 AM, Wenier said: Coils will normally show by breaking down under load. Say 4th gear going full throttle and it will be fine until the RPM starts to get up a bit then usually a power loss/shuddering feeling.mine does that some times after a quick boot and it can shudder after some times when revs are down low. Like a lawn mower with sh*t fuel. If you know what I mean. Link to comment https://www.fordxr6turbo.com/forum/topic/90748-rough-idle/#findComment-1550380 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 11m 25d Gender: Male Location: Gold Coast Posted 26/06/15 10:45 AM Share Posted 26/06/15 10:45 AM Had a bit of time this arvo so cleaned the throttle body again as I too had an occasional pop at no load idle. It was grubby around the edges of the butterfly and internally a little. Anyway, pleased to report with a quick clean up with Nulon TB cleaner, the fault is gone. Link to comment https://www.fordxr6turbo.com/forum/topic/90748-rough-idle/#findComment-1550423 Share on other sites More sharing options...
Nugget New Member 8 Member For: 9y 10m 25d Posted 28/06/15 07:04 AM Author Share Posted 28/06/15 07:04 AM Yeh I've cleaned the throttle body and that's not the issue... My mate said it could possibly be the sparks... I pulled one of them out today and they look worn out.. so gonna change them and also the coils and I'll see how I go... Link to comment https://www.fordxr6turbo.com/forum/topic/90748-rough-idle/#findComment-1550591 Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 11m 17d Posted 29/06/15 04:16 AM Share Posted 29/06/15 04:16 AM I would still check your engine mounts Link to comment https://www.fordxr6turbo.com/forum/topic/90748-rough-idle/#findComment-1550726 Share on other sites More sharing options...
