Silverfox666 Member 117 Member For: 10y 5m 5d Gender: Male Location: Sydney penrith Posted 21/06/15 01:18 AM Share Posted 21/06/15 01:18 AM (edited) My car has 393rwkw and I kept the cross over what I was wondering does a turbo side intake and battery relocation equal more power or is it for turbo noise and something people just do for the looks basically is there any big power gain from doing it that way compared to the cross over and herrod CAI .... Cheers Edited 21/06/15 01:19 AM by Silverfox666 Link to comment https://www.fordxr6turbo.com/forum/topic/90723-turbo-side-air-box/ Share on other sites More sharing options...
julesk_1972 Member 267 Member For: 12y 10m 6d Gender: Male Location: Perth Posted 21/06/15 01:39 AM Share Posted 21/06/15 01:39 AM Pretty sure it's all noise from a turbo side intake.Might be different scenario if going for big hp and running a larger turbocharger.I run stock intake pipe route with a growler air box, 399rwkw.Sent from my HTC One_M8 using Tapatalk Link to comment https://www.fordxr6turbo.com/forum/topic/90723-turbo-side-air-box/#findComment-1549615 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 8m 28d Gender: Male Location: Townsville Posted 21/06/15 03:34 AM Share Posted 21/06/15 03:34 AM There is power gain due to the increased size of the intake itself (generally 4in tapering to comp housing size) the and the shortness of the intake. Air is cooler also which makes a power difference even if it's a little one...Simple tests (which I have help do and seen done also) include on a dyno do an initial run when at operating temps then undo the standard intake box (4-5 clips and lift up the intake to face into the fan and do another run, this will show an initial leaner mixture down low with an increase in spool and overall power (I'm not sh!tting you) and finally remove the pipe off the compressor housing so that there is no intake or restrictions and run it again... Watch and see! None of that is tech-a-nogical now is it so easy as p!ss to do! Link to comment https://www.fordxr6turbo.com/forum/topic/90723-turbo-side-air-box/#findComment-1549620 Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 12y 1m 25d Gender: Male Location: A big bridge over a river in South Australia Posted 21/06/15 04:13 AM Share Posted 21/06/15 04:13 AM Sleeper look for me and my 400Turbo side will def give a bit quicker spool - if that's what you're after 3 Link to comment https://www.fordxr6turbo.com/forum/topic/90723-turbo-side-air-box/#findComment-1549623 Share on other sites More sharing options...
Robos F6 Donating Members 407 Member For: 16y 2m 30d Gender: Male Location: Vic Posted 21/06/15 05:01 AM Share Posted 21/06/15 05:01 AM Im running a standard BF intake and I picked up 30rwkw coming straight out of the turbo compressor. FG would be less. Link to comment https://www.fordxr6turbo.com/forum/topic/90723-turbo-side-air-box/#findComment-1549634 Share on other sites More sharing options...
Silverfox666 Member 117 Member For: 10y 5m 5d Gender: Male Location: Sydney penrith Posted 21/06/15 06:31 AM Author Share Posted 21/06/15 06:31 AM Ok thanks for the replies , so if there is a gain its only minimal so ,not enough to warrant a retune , it's mainly a noise thing Link to comment https://www.fordxr6turbo.com/forum/topic/90723-turbo-side-air-box/#findComment-1549645 Share on other sites More sharing options...
julesk_1972 Member 267 Member For: 12y 10m 6d Gender: Male Location: Perth Posted 21/06/15 06:47 AM Share Posted 21/06/15 06:47 AM How do u get quicker spool with a turbo side??Sent from my HTC One_M8 using Tapatalk Link to comment https://www.fordxr6turbo.com/forum/topic/90723-turbo-side-air-box/#findComment-1549647 Share on other sites More sharing options...
Wilko16 Donating Members 1,672 Member For: 17y 6m 11d Gender: Male Location: Melbourne Posted 21/06/15 08:41 AM Share Posted 21/06/15 08:41 AM Less resistance on the airflow to the turbo 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90723-turbo-side-air-box/#findComment-1549667 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 5d Gender: Male Location: @ my laptop Posted 21/06/15 10:52 AM Share Posted 21/06/15 10:52 AM my wifes G6ET picked up 2 lbs on 1 run when trying a turbo side air box 3 Link to comment https://www.fordxr6turbo.com/forum/topic/90723-turbo-side-air-box/#findComment-1549686 Share on other sites More sharing options...
Robos F6 Donating Members 407 Member For: 16y 2m 30d Gender: Male Location: Vic Posted 21/06/15 01:13 PM Share Posted 21/06/15 01:13 PM On 21/06/2015 at 10:52 AM, ratter said: my wifes G6ET picked up 2 lbs on 1 run when trying a turbo side air boxYep we picked up an extra 2psi as well Link to comment https://www.fordxr6turbo.com/forum/topic/90723-turbo-side-air-box/#findComment-1549701 Share on other sites More sharing options...
