Au Brembos On Fg Xr6T
doobs
  • Moar Powar Babeh
  • Member For: 19y 4m 6d
I wouldn't be too keen to run them in that position though. Anything below the centre line of the wheel can expose the calliper to higher deflection loads from the wheel bearings (which can lead to pad knock off) and also potentially have a negative effect on the anti dive/squat geometry built into the suspension
  • Member For: 17y 2m 5d
Fark me, always something you don't know about with these things.
It's almost like they are complex machines or something.
  • New Member
  • Member For: 13y 2m 14d
Looking better now.
If you have a Lambo then its ok to be under the center line...
Part numbers on calipers are as follows:
Front Calipers:
20.7678.00 (outer)
20.7679.00 (inner)
Rear Calipers:
6972 (outer)
6971 (inner)
  • Like 2
  • Member For: 16y 6m 13d
Anychance you could post the PN's on the calipers (and photos of) Just interested to see how the piston sizing compares to others out there.
Notes from my collection:
Six Piston Brembo Calipers - Part Numbers
Front LH Caliper:
LHF Ford or FPV part no: BAFT 2B119 A 20A00420, Casting no: 20.A001.01 1A
On mine:
White sticker on the side: 20A00410
White sticker on the bottom: 8026 2B119 AB
Casting on caliper: 20.A001.01 1A
Casting on mounting bracket: 20.A002.03
Front RH Caliper:
RHF Ford or FPV part no: BAFT 2B118 A 20A00420, Casting no: 20.A001.02 1A
On mine:
White sticker on side: 20A00420
White sticker on bottom: 8026 2B118 AB
Casting on caliper: 20.A001.02 1A
Casting on mounting bracket: 20.A002.04
Rear RH Caliper:
RHR Ford or FPV part no: BAFT 2K327 A 20766244, 8026 2K327 AB
On mine:
White sticker on side: 20766244
White sticker on bottom: 8026 2K327 AB
Casting on calliper: none, except for 02H90
Casting on mounting bracket: 20.A002.00
Rear LH Caliper:
LHR Ford or FPV part no: BAFT 2K328 A 20766234, 8026 2K328 AB
On mine:
White sticker on side: 20766234
White sticker on bottom: 8026 2K328 AB
Casting on caliper: none, except for 06H25
Four Piston Calipers
Part Numbers - Front Calipers (on the inside, above piston):
20.7678.01 1A (outer)
20.7679.01 1A (inner)
Same part numbers on both the 36/40mm and 40/44mm versions.
Part Numbers - Rear Calipers (on the inside, above piston):
6972 (outer)
6971 (inner)
Part Numbers - Front Brackets:
20.A002.01 and 20.A002.02
19.7681.18 and 19.7681.19
Part Numbers - Rear Caliper Brackets
R20.8415.90 - both sides
Bolts - Caliper to Bracket Bolts
Front: 70 x 1.5 x M12
Quantity: 2 on each caliper
Bolts - Rear: 55 x 1.5 x M12
Caliper Pad Springs & Pins
2 x front springs, 4 pins
2 x rear springs, 4 pins
Caliper Connecting Bolts
Front: 90 x 1.75 x M12
Quantity: 4 per caliper
Rear: 75 x 1.75 x M12
  • 3 weeks later...
  • Member For: 16y 10d
Doob,
Half your luck mate. They look great. And if you got them at a good price, even better. If I'd stumbled across a good deal I would have been tempted to do the same even though I'd have to source a set of 19" rims. I decided to stick with the factory XR6T rims so I fitted DBA T3 rotors and Ferodo pads and they make a BIG difference. It's a shame that they still look like taxi brakes.
