Vevapower Waiting for the 1st N/A 12! Donating Members 2,533 Member For: 17y 4m 17d Gender: Male Location: Sydney Posted 25/08/15 12:18 PM Share Posted 25/08/15 12:18 PM 12 cc pistons Link to comment https://www.fordxr6turbo.com/forum/topic/90692-need-honest-help-on-fuel-supply-for-500awkw/page/7/#findComment-1559372 Share on other sites More sharing options...
Grego.77 Member 195 Member For: 10y 7m 9d Gender: Male Location: St Clair NSW Posted 25/08/15 12:43 PM Author Share Posted 25/08/15 12:43 PM I kept it at 20" unless the machine shop stuffed up (its happened to me twice before). Find out early next week when I go to pick her up. Im actually pretty keen to see the difference Link to comment https://www.fordxr6turbo.com/forum/topic/90692-need-honest-help-on-fuel-supply-for-500awkw/page/7/#findComment-1559376 Share on other sites More sharing options...
Grego.77 Member 195 Member For: 10y 7m 9d Gender: Male Location: St Clair NSW Posted 05/09/15 07:26 AM Author Share Posted 05/09/15 07:26 AM On 24/08/2015 at 9:54 AM, Vevapower said: that's what I got Greg those exact je's and run 9.4 to 1 works a treat.Mate my cams are miles out now!!! If I leave it the way it is my cams are way to retarded pretty much 0.0" @tdc if I go a whole link Im too advanced about 0.150" Im so far advanced I need to fly cut eye brows into my pistons???? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90692-need-honest-help-on-fuel-supply-for-500awkw/page/7/#findComment-1560594 Share on other sites More sharing options...
Grego.77 Member 195 Member For: 10y 7m 9d Gender: Male Location: St Clair NSW Posted 05/09/15 08:44 AM Author Share Posted 05/09/15 08:44 AM Looks like half a tooth is going to work lol... it lines up?? either that or I buy a 1.3mm head gasket and end up with 8.8:1 comp again.... I cant believe this motor...guess I can blow more $$ and buy atomic adjustable cam gears.If I was to do this again Id be buying the largest undersized rod bearings and give it a slight stroke or buy flat tops with just 5cc eye brows cut on all 4s. I don't even know why they put valve reliefs on the exhaust side when its the intake that has clearance issues.Im guessing my timing cover case aint going to fit either now?? Link to comment https://www.fordxr6turbo.com/forum/topic/90692-need-honest-help-on-fuel-supply-for-500awkw/page/7/#findComment-1560607 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 28d Gender: Male Location: Adelaide Posted 05/09/15 08:52 AM Share Posted 05/09/15 08:52 AM Sounds like you need to run your calcs twice and buy once buddy Lucky u build/t some kick arse V8's in your time .........Little 4.0 has you well bent over 2 Link to comment https://www.fordxr6turbo.com/forum/topic/90692-need-honest-help-on-fuel-supply-for-500awkw/page/7/#findComment-1560608 Share on other sites More sharing options...
Grego.77 Member 195 Member For: 10y 7m 9d Gender: Male Location: St Clair NSW Posted 05/09/15 01:38 PM Author Share Posted 05/09/15 01:38 PM Its got me bent over HARD!!! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90692-need-honest-help-on-fuel-supply-for-500awkw/page/7/#findComment-1560651 Share on other sites More sharing options...
Grego.77 Member 195 Member For: 10y 7m 9d Gender: Male Location: St Clair NSW Posted 06/09/15 03:19 AM Author Share Posted 06/09/15 03:19 AM Iv measured twice and bought once, not fault retarded piston manufactures put valve reliefs on the wrong side. Even if I ran a 0.650" lift cam on the exhaust side she still wont require those valve reliefs. Ex is purplethat's measured @ standard lift on a standard cam .015 deck clearance .015" service limit left on head .012" head gasket roughly 9.3:1 comp ratioIts no problem this happens to a lot of built engines. Just needs valve reliefs cut on the CORRECT side. Cams are being adjust via Delrin on the tension side of the cam. Link to comment https://www.fordxr6turbo.com/forum/topic/90692-need-honest-help-on-fuel-supply-for-500awkw/page/7/#findComment-1560691 Share on other sites More sharing options...
