Need Honest Help On Fuel Supply For 500Awkw
Grego.77
  • Member For: 10y 2m 13d
If you have a decent tuner, they will sort it out.
Iv got a decent tuner I just want to be able to do as much work as possible myself before it gets the tune for 2 reasons 1 is some satisfaction that Iv done it myself and the other is I dont want a poor result and having to repay for dyno tuning because I had insufficient fuel flow. Iv got full faith in my tuner who is Joe from CMS and he suggested an in tank set up and told me its worth $1695 he didnt say how many ponnies Ill get but Im guessing it should be good for around 500awkw.
Am I asking too much??
  • Member For: 20y 6m 10d
Sounds like an awesome build.
If you have the money go with Joe's suggestion. The KPM units are a hit at the moment.
If short on funds there are cheaper options with an external surge
  • Waiting for the 1st N/A 12!
  • Member For: 16y 11m 21d
Big powered Terries always lunch Half shafts....
Also you'll need bigger than 1000cc injectors as well.
Go with the KPM 1500 drop in module really can;t go wrong there.
Yeah, I am curious on this one too. I would have though the external surge allows for a greater margin of error / redundancy.
If you are starting from scratch I would get going upfront with the KPM drop in system.
I spoke to the boys at KPM and they were pretty helpful and honest in the sense that they have never installed or known anyone to have installed one of their units to a territory. They asked me to pull my unit out and take photos and measurements and they were pretty confident that they will be able to say yay or nay. They asked whos tuning the car and I said Joe from CMS they said he should have 1 in stock to compare. Im pretty sure 1000kpm injectors can produce 500kw only because a very good friend of mine is running 1000cc injectors in his WRX and is pulling 418 awkw from a little 2 liter. His running twin 044s and a 2l surge tank all external. My mistake was starting this project just wanting 300kw but being a NA man through and through I hated the slugish/laggy unresponsive feel of a turbo especially on a hot day or after sitting at traffic lights. So than came the Plazmaman FMIC than I noticed I had 2 dead cylinders after doing a head-on valve spring change than no one will give me warranty on a rebuilt box unless I go billet in and cryo out shafts so before I knew it I hit over $10k and decided to buy a second hand low km FG engine wreckers asking to much so I bought forged internals along with oil pumps timing gear screw in studs ect ect and Im guessing you know how it goes. I like to do things right the first time and not do them again. I really thank the guys who I have pm and you guys for giving me some insight on where I go from here and with your input and advice Ill try my hardest to go with the twin KPM intank setup and keep my fingers crossed on what the old girl pulls.
  • Silver Donating Members
  • Member For: 11y 9m 29d
Correct me if I'm wrong, but I believe the kpm twin pump fuel modules only work with the BF2-FG style tank which has a retaining ring that twists into place, where as the screw in type is the BA style??
I fitted an FG tank to my BF for this reason
