PTR_NITRO_FG Donating Members 3,214 Member For: 12y 16d Gender: Male Location: NOR Perth Posted 07/06/15 01:42 PM Share Posted 07/06/15 01:42 PM So how do people make ba/bf brembos fit on fg?I thought you just take off brackets and flipped it around or something? Link to comment https://www.fordxr6turbo.com/forum/topic/90646-6-spot-brembos-fg/page/2/#findComment-1547973 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 1m 9d Gender: Male Location: Western Sydney Posted 07/06/15 01:45 PM Share Posted 07/06/15 01:45 PM Flip the B series callipers to suit the FG brackets. Link to comment https://www.fordxr6turbo.com/forum/topic/90646-6-spot-brembos-fg/page/2/#findComment-1547974 Share on other sites More sharing options...
Pixy Angel Expert Donating Members 9,132 Member For: 20y 3m 15d Gender: Male Location: North Jamberoo, NSW Posted 07/06/15 09:27 PM Share Posted 07/06/15 09:27 PM would like a set of 6/4 behind the G6E wheelsI think AP Racing make a set. Link to comment https://www.fordxr6turbo.com/forum/topic/90646-6-spot-brembos-fg/page/2/#findComment-1547988 Share on other sites More sharing options...
sixman Donating Members 601 Member For: 20y 10m 20d Gender: Male Location: Hills District, NSW Posted 07/06/15 09:28 PM Share Posted 07/06/15 09:28 PM Have a chat to Matt at race brakes. He sometimes gets excess kits in cheap. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/90646-6-spot-brembos-fg/page/2/#findComment-1547989 Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 5m 2d Gender: Male Posted 07/06/15 10:57 PM Share Posted 07/06/15 10:57 PM (edited) Ap racing your looking at like 5k for their 4/4 setup and 6500 for their 6/4, these are couple year old prices too! Replacement rotors are more expensive too altho they are 362mm so better stopping power. Fit under less wheels though!Then there's shockworks 4pot mono blocks (they're still working on the rears though). I think 1800-2000 for rotor caliper and pads, replacement rotors aren't cheap though at 900 or 1100-1200 for the two piece, but they supply the Korean v8supercar series so they should do the job.The above probably not useful for OP but for discussion on further brake options. I researched this a bit myself last year before going a brembo 6/1 setup with rear territory caliper, with track work in mind. Edited 07/06/15 11:00 PM by Bulletime 2 Link to comment https://www.fordxr6turbo.com/forum/topic/90646-6-spot-brembos-fg/page/2/#findComment-1547993 Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 10m 25d Gender: Male Location: Perth, Western Australia Posted 08/06/15 01:17 AM Share Posted 08/06/15 01:17 AM Fitting BA/BF six piston Brembo calipers to FG: According to Matt at Race Brakes Sydney, the brackets swap over, but the crossover pipes don't. Hence, new crossover pipes need to be made by a brake place.With the four piston calipers, both the brackets and crossover pipes swap over easily. Link to comment https://www.fordxr6turbo.com/forum/topic/90646-6-spot-brembos-fg/page/2/#findComment-1548005 Share on other sites More sharing options...
FormulaFG Donating Members 68 Member For: 10y 11m 24d Posted 14/06/15 01:08 PM Share Posted 14/06/15 01:08 PM Would it be acceptable to go with a 6 pot upgrade on the front and leave the standard xr6 turbo caliper on the rear?Will this throw anything out of balance or be in any way a generally bad idea? Link to comment https://www.fordxr6turbo.com/forum/topic/90646-6-spot-brembos-fg/page/2/#findComment-1548820 Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 10m 25d Gender: Male Location: Perth, Western Australia Posted 14/06/15 01:20 PM Share Posted 14/06/15 01:20 PM (edited) On 14/06/2015 at 1:08 PM, FormulaFG said: Would it be acceptable to go with a 6 pot upgrade on the front and leave the standard xr6 turbo caliper on the rear?Will this throw anything out of balance or be in any way a generally bad idea?Yep, that'll work fine.If you're keen then grab some 328mm rear brakes as well. Besides being a larger diameter (328m vs 303mm) they are also vented instead of the solid smaller discs. Edited 14/06/15 01:20 PM by PhilMeUp Link to comment https://www.fordxr6turbo.com/forum/topic/90646-6-spot-brembos-fg/page/2/#findComment-1548823 Share on other sites More sharing options...
burkey05 Member 76 Member For: 11y 1m 24d Gender: Male Location: Melbourne Posted 14/06/15 11:54 PM Share Posted 14/06/15 11:54 PM On 08/06/2015 at 1:17 AM, PhilMeUp said: Fitting BA/BF six piston Brembo calipers to FG: According to Matt at Race Brakes Sydney, the brackets swap over, but the crossover pipes don't. Hence, new crossover pipes need to be made by a brake place.With the four piston calipers, both the brackets and crossover pipes swap over easily.when you say the brackets swap over for the 4 pots, do you mean you use the BA/BF brackets on the FG? or you have to source FG brackets? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90646-6-spot-brembos-fg/page/2/#findComment-1548839 Share on other sites More sharing options...
julesk_1972 Member 267 Member For: 12y 10m 16d Gender: Male Location: Perth Posted 15/06/15 11:31 AM Share Posted 15/06/15 11:31 AM I tried custom BA/BF brackets on my FG for CP6600 calipers, did not fit.:(Sent from my HTC One_M8 using Tapatalk Link to comment https://www.fordxr6turbo.com/forum/topic/90646-6-spot-brembos-fg/page/2/#findComment-1548930 Share on other sites More sharing options...
