Ribby Member 75 Member For: 12y 6m 18d Gender: Male Location: Gladstone QLD Posted 24/05/15 05:04 AM Share Posted 24/05/15 05:04 AM looking at buying a set of 6 front 4 rear brembos of a gt. its a stat rightoff for about 3000$ will they fit on my fg xr6t. whats your guys thoughts. Link to comment Share on other sites More sharing options...
Seaton Donating Members 537 Member For: 12y 6m 12d Gender: Male Location: Sydney Posted 24/05/15 05:14 AM Share Posted 24/05/15 05:14 AM Yes. Mine came from a written off gt also Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 5m 18d Gender: Male Location: Perth, WA Posted 24/05/15 05:44 AM Share Posted 24/05/15 05:44 AM Should bolt straight on to an FG XR6T sedan. You will need to trim the rear dust plate to accommodate the larger calliper.I could be wrong but from memory sedan rears are different to ute, so if you have a ute the rear will not fit. Link to comment Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 7m 23d Gender: Male Location: Perth, Western Australia Posted 24/05/15 09:46 AM Share Posted 24/05/15 09:46 AM (edited) Yeah, it's a very simple bolt on.Get a flare spanner to help with removing the existing brake lines - a normal spanner might round off the nuts. I have a 10mm & 11mm combo flare spanner for that. Fitting Brembo brakes to a BF back in 2011: http://www.fordxr6turbo.com/forum/topic/78765-photo-essay-fitting-brembo-brakesWhen fitting, use a drill and wire brush to clean the relevant metal surfaces - the insides of the disc rotors and where they go on the car (ie wheel bearing hubs). I also clean up the wheel studs and put a bit of grease on each one after that to prevent wheel nuts from seizing on (had that before).Before fitting, it would be worth taking the discs to a brake place and having them checked to ensure there is no run-out (ie brake shudder) before doing all the work. ie Edited 24/05/15 09:47 AM by PhilMeUp 1 Link to comment Share on other sites More sharing options...
