Walbro 460 Fuel Pump
  • Member For: 17y 3m 17d
Is anyone using a Walbro 460lph E85 compatible fuel pump in the standard sender unit and if so was there any drama with higher fuel pressure / richer mixture associated with the swap? Cheers!
  • Bronze Donating Members
  • Member For: 10y 11m 22d
Iv got that pump in the stock sender in my ute. Running standard lines and reg. The reg and return lines are just up to the job but they recommend a new reg and return lines to avoid high fuel pressure at idle.
Oh dear! I can see an aftermarket regulator in sight.
I might put a gauge on it and see exactly what the pressure difference is.
Are you guys using the standard wiring configuration or have run a new power supply to the sender?
  • Silver Donating Members
  • Member For: 10y 9m 13d
I'm also running an intank 460, got as replacement drop-in unit cos too lazy to swap pump only
Needed new relay as well as reg, relay was approx $120 from KPM from memory
Geez that's up there. Is there anything special about the relay? I was going to run a fused feed from the battery and switch a relay via the original pump power feed.
You're right it's pricey
Bought it because I didn't know any better
Nothing special, pic of it in the following link:
http://www.kpmauto.com/tabid/223/ProductID/248/Default.aspx
