Sasha Member 141 Member For: 17y 10m 26d Gender: Male Location: North Queensland Posted 20/05/15 02:24 PM Share Posted 20/05/15 02:24 PM Is anyone using a Walbro 460lph E85 compatible fuel pump in the standard sender unit and if so was there any drama with higher fuel pressure / richer mixture associated with the swap? Cheers! Link to comment https://www.fordxr6turbo.com/forum/topic/90550-walbro-460-fuel-pump/ Share on other sites More sharing options...
bamk2f6tornado Bronze Donating Members 777 Member For: 11y 7m 1d Gender: Male Location: Rockhampton Qld Posted 20/05/15 07:41 PM Share Posted 20/05/15 07:41 PM Iv got that pump in the stock sender in my ute. Running standard lines and reg. The reg and return lines are just up to the job but they recommend a new reg and return lines to avoid high fuel pressure at idle. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90550-walbro-460-fuel-pump/#findComment-1545401 Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 2m 11d Gender: Male Posted 21/05/15 01:26 AM Share Posted 21/05/15 01:26 AM Your most likely running above 4 bar delta now more in the vicinity of 70psi plus.There are ways to mod the cradle to allow better return flow. Link to comment https://www.fordxr6turbo.com/forum/topic/90550-walbro-460-fuel-pump/#findComment-1545424 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 8m 15d Posted 21/05/15 02:32 AM Share Posted 21/05/15 02:32 AM I have the walbro 460 in my surge and had up around 90-100psi and so had to get a reg. Even though yours is as a lift pump in the tank I would imagine fuel pressure would still be quite high Link to comment https://www.fordxr6turbo.com/forum/topic/90550-walbro-460-fuel-pump/#findComment-1545427 Share on other sites More sharing options...
Sasha Member 141 Member For: 17y 10m 26d Gender: Male Location: North Queensland Posted 21/05/15 09:18 AM Author Share Posted 21/05/15 09:18 AM Oh dear! I can see an aftermarket regulator in sight.I might put a gauge on it and see exactly what the pressure difference is.Are you guys using the standard wiring configuration or have run a new power supply to the sender? Link to comment https://www.fordxr6turbo.com/forum/topic/90550-walbro-460-fuel-pump/#findComment-1545465 Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 4m 22d Gender: Male Location: SW Sydney Posted 21/05/15 01:39 PM Share Posted 21/05/15 01:39 PM I'm also running an intank 460, got as replacement drop-in unit cos too lazy to swap pump onlyNeeded new relay as well as reg, relay was approx $120 from KPM from memory Link to comment https://www.fordxr6turbo.com/forum/topic/90550-walbro-460-fuel-pump/#findComment-1545521 Share on other sites More sharing options...
Sasha Member 141 Member For: 17y 10m 26d Gender: Male Location: North Queensland Posted 22/05/15 06:30 AM Author Share Posted 22/05/15 06:30 AM On 21/05/2015 at 1:39 PM, camo86T said: I'm also running an intank 460, got as replacement drop-in unit cos too lazy to swap pump onlyNeeded new relay as well as reg, relay was approx $120 from KPM from memoryGeez that's up there. Is there anything special about the relay? I was going to run a fused feed from the battery and switch a relay via the original pump power feed. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90550-walbro-460-fuel-pump/#findComment-1545608 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 10m Gender: Male Location: Townsville Posted 22/05/15 08:55 AM Share Posted 22/05/15 08:55 AM I'd hope that was a plug and play relay harness that they installed also for the $120!!! 2 Link to comment https://www.fordxr6turbo.com/forum/topic/90550-walbro-460-fuel-pump/#findComment-1545635 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 10m 28d Gender: Male Location: Adelaide Posted 22/05/15 10:14 AM Share Posted 22/05/15 10:14 AM Street fighter sticker. $100 bucks right there for the sticker alone. Relay $20 2 Link to comment https://www.fordxr6turbo.com/forum/topic/90550-walbro-460-fuel-pump/#findComment-1545653 Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 4m 22d Gender: Male Location: SW Sydney Posted 23/05/15 06:39 AM Share Posted 23/05/15 06:39 AM On 22/05/2015 at 6:30 AM, Sasha said: Geez that's up there. Is there anything special about the relay? I was going to run a fused feed from the battery and switch a relay via the original pump power feed.You're right it's priceyBought it because I didn't know any betterNothing special, pic of it in the following link:http://www.kpmauto.com/tabid/223/ProductID/248/Default.aspx 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90550-walbro-460-fuel-pump/#findComment-1545750 Share on other sites More sharing options...
