Fuel Filter Change Over
  • Too heavy needs boost
  • Member For: 11y 3m 19d
My phone is being a karnt and will not let me fully search the fourm for a thread.
Just want to know how often a fuel filter should be changed on a modded car. Car only runs bp98 and it has been on maybe 25-30k. Any tips for removing the old one and what would be the best filter to put on. Stock ford one, after market one?
Cheers
  • in the mid....not the bum like some
  • Member For: 11y 7m 2d
KPM one is north of 200 dorrah.
Pretty sure its a 19mm and a 14mm spanner from memory.
When on E85 and using the stock lines I used the Cooper filter and held up for 10k no worries(glue not sh*tting itself).
Cant go wrong with a genuine one though Id imagine :)
  • Like 2
  • XR50T
  • Member For: 11y 6m 24d
Goleby's have a direct fit E85 rated filter that has a removable cleanable core. Looks like a good bit of gear and was $100 delivered.
  • Like 3
  • Member For: 11y 5m 30d
Hopefully Ralph will correct me if im wrong....but a while back I think he said something like every oil change if running e85 (cleaning an afternarket filter that is)...then once per year if using OEM (which I assume means every 20,000kms) for stock on 98?
So maybe every 2nd oil change for you Bizkarnt?
But this is only speculating :P
Beard
Edited by PTR_NITRO_FG
  • Member For: 11y 7m 3d
I looked into the golebys one,only 40 micron filtration.The 40micron kpm one is $225 and $245 for the 10 micron kpm filter.Ive been told we want a minimum of 10 micron filtration.Still the golebys filter looks identical to the kpm filters,
