My 2010 XR50T Ute
OZYWALKER
  • XR50T
  • Member For: 11y 6m 7d
Going to pull the intake manifold with surge tank lines and rail out this week/weekend.
$1600 for the fuel system. Consists of PW surge tank with twin 460s, turbosmart fpr2000, speedflow fittings and check valves to fit up to the PW billet fuel rail.
$450 for the intake manifold.
$400 for the TB elbow with turbosmart dual port 32mm BOV and Nizpro overboost valve.
Will put pics up in an add once they're out.
  • XR50T
Pretty much. Piping and BOV/overboost valve won't suit how I want it setup with the Plaz intake manifold.
The Process West surge doesn't have the fuel capacity for bigger power and the Plazmaman manifold comes with a new rail so the Process West gears going.
  • XR50T
I wish haha.
Just finding the current power level pretty average. I'm getting all the bolt on parts together and fitted up so there's no mucking around when a new motor goes in later this year. That's the plan anyway.
  • 1 month later...
  • XR50T
Made some progress with the Ute over the last few weeks. Pulled out the Process West airbox, rail lines and surge tank out on a Sunday and fitted the new gear when there was time after work.
Now have a Plazmaman airbox, intake plenum, fuel rail and surge tank with twin peirburg pumps.
I used Mack 247 fittings and lines for the fuel and vac lines.
I ran 400 series pushlock hose for the fuel system, -6 supply and -8 return with an FRP2000.
Replaced the brake booster fitting with an aftermarket with a -6 end then ran -6 400 series to the intake manifold. Also used -4 pushlock for the other vac lines. Have used oetiker clamps on all hose ends. Will be using the remaining NPT port on the manifold for a gauge line/fitting and to use a "normal" vac hose for tuning purposes.
Should have some new turbosmart race port BOVs show up soon then I'll have a new cold side fabbed up. Also have some 50mm2 cable and other parts showing up soon to relocate the battery to the toolbox in the tray.
  • Like 6
  • XR50T
Also ran a new water line and fitted a bracket I got from Mackielec Industries.
Looks pretty decent comprared to the previous way I had it, will swap the cable ties to hose seperators one day.
  • Like 6
