  • XR50T
  • Member For: 12y 1m 15d
Old ones were XXR 550.
Fronts 18x8.75 +36 with 255/40R18.
Rears 18x9.75 +36 with 295/35R18.
Would suit 245 fronts and 285 rears better as they bulged a bit.
  • 3 weeks later...
  • XR50T
It will be when it get sorted out at CMS.
Has a bunch of issues since the conversion happened. ABS, DSC and airbag warnings and a few other things need to be sorted out.
Really looking forward to having the cams done, getting CMS stage 2 cams fitted. They'll also be doing headstuds, valve springs (again), atomic vernier cam sprockets and all the atomic timing gear.
Did do a bit to it after work last week. Fitted heavier rear coils and added a bit of preload to the fronts, so now it's got 12kg front and 9kg rear springs. Rides nice and firm and seems pretty well balanced now.
Also fitted some aerocatch hood pins, managed to tear up a fair bit of clear coat when I pulled the masking tape off so I'll have to get it resprayed once it comes back from CMS.
  • XR50T
Not at them moment. Granny tune to run the clutch in.
Will be that way for a few weeks, goes to CMS next Monday.
  • Member For: 9y 1m 29d
Expand
Next time u go using a grinder on your car.
Grab a candle and run the metal disc through it before every cut of metal,
Helps to keep the heat down and the disc runs much smoother during cutting.
Info u needed last week haha
  • XR50T
Did that exact thing haha. Was a cheap average paint job on the bonnet to start with so I'm not too fussed.
  • XR50T
Dropped it at CMS this arvo.
Will probably take a few weeks to sort out the gremlins it has.
Asides from that it's getting:
CMS stage 2 cams (new billets)
Head studs
New valve springs and retainers
Atomic vernier cam gears
Atomic timing chain
Atomic hardened sprocket
Atomic tensioner and guide
Definately looking forward to getting it back, have heard these cams in other cars and I'm a fan.
  • Like 4
