My 2010 XR50T Ute
OZYWALKER
  • 1 month later...
  • XR50T
  • Member For: 11y 8m 9d
So I've had to hold of on the wheels for a bit. Had some tools knocked off from site a few weeks back, so everything's slowed up a bit for now.
Hopefully I'll be having the tyres fitted on the weekend but won't have time to sort the guards or camber brackets out for a few weeks at least.
Next up before the guard work is a manual conversion. I have lined up a compete manual conversion from a low km hail damaged FG Mk2 ute and will be having that all fitted in 2 or so weeks.
At this stage I know the rear guards will need a heap of work to fit the new wheels and tyres so if there's room to move them inwards I'll sort out a B series axle as they're around 50mm narrower than the FG axle.
  • XR50T
Just a wee bit of poke.......
Fronts will be right once rolled and camber is sorted.
The rear rims sit flush with the guard but the pirrellis are pretty wide and I don't want to have the stretched look. I'll probably sort a b series axle to fix that, cant see the guards pumping out that much.
  • Like 9
  • 3 weeks later...
  • XR50T
So the manual conversion is all sorted mechanically. Did it all at a local wreckers which was great as spares were a plenty and there were a lot more parts involved than I'd thought.
We used a manual engine harness instead of modifying the auto harness. Had a standard reconditioned tail shaft fitted. The rest was all stock parts from the donor ute.
Was surprised to find all the flex plate bolts were tight considering how it has been driven.
Removing and fitting the starter motor with a process west surge tank is a dog of a job, made it even worse as I have a catch can fitted there as well.
Have a tune issue at the moment. Returned it to stock tune prior to pulling anything out but now it doesn't want to accept the new tune. Will have to have it trucked home tomorrow and have the tune issue sorted out in the next week or so.
Only managed to get one pic of it during the job.ad9a213d7941dd54829b62f7f10d270a.jpg
  • Like 4
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 7m 10d
The old long extension bar on a battery rachet gets the starter motor bolts out from the front by underneath the thermostat housing ;)
  • XR50T
That's a bloody long extension hey, ended up using a ratchet spanned cos chit was in the way.
Any ideas why the bitch won't take a tune? Pm if you want.
