OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 1m 12d Gender: Male Location: Western Sydney Posted 20/09/15 02:23 AM Author Share Posted 20/09/15 02:23 AM The whole kit with piping, clamps and brackets felt a fair bit less that the PW cooler alone. I'd say the cooler itself would be around half the weight or less. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/3/#findComment-1562458 Share on other sites More sharing options...
10SECN Member 516 Member For: 12y 1m 11d Gender: Male Location: west hoxton Posted 20/09/15 02:53 AM Share Posted 20/09/15 02:53 AM Nice car buddy. What's the story with the thermostat housing. ? What did u have to do to make it fit and or where do u get them ? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/3/#findComment-1562463 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 1m 12d Gender: Male Location: Western Sydney Posted 20/09/15 03:16 AM Author Share Posted 20/09/15 03:16 AM Its a modified aftermarket GM part, a "manifild filler neck". I had the bolt holes moved in and the center bored out to match the factory size.Easiest and neatest way to do something similar would be to get a spare tstat housing from a wreckers, cut a hole in it and get a filler neck welded to it.Then have the blank outlet nipple on the factory tstat housing tapped and run a line to the top of the radiator on the as its the highest point, without this you'll end up with an air gap in the top of the radiator.You also need a plug to block the 1'' radiator outlet that runs to the header tank.Also I found that you have to use at least a 21psi radiator cap not a 16psi like the stock setup or it will loose a lot of coolant on shutdown. Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/3/#findComment-1562464 Share on other sites More sharing options...
10SECN Member 516 Member For: 12y 1m 11d Gender: Male Location: west hoxton Posted 20/09/15 03:28 AM Share Posted 20/09/15 03:28 AM Cool. Thanks for the info Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/3/#findComment-1562465 Share on other sites More sharing options...
julesk_1972 Member 267 Member For: 12y 10m 18d Gender: Male Location: Perth Posted 20/09/15 12:50 PM Share Posted 20/09/15 12:50 PM How much power are you chasing????? Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/3/#findComment-1562499 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 1m 12d Gender: Male Location: Western Sydney Posted 20/09/15 06:56 PM Author Share Posted 20/09/15 06:56 PM Sorry, missed your other post. Will see how it goes once the box gets built. Will probably be pushing just under the 500rwkw mark with the stock motor then have a motor built down the track. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/3/#findComment-1562507 Share on other sites More sharing options...
julesk_1972 Member 267 Member For: 12y 10m 18d Gender: Male Location: Perth Posted 20/09/15 09:26 PM Share Posted 20/09/15 09:26 PM Would be great to read your observations on how the new cooler performs in comparison to previous setup. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/3/#findComment-1562510 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 1m 12d Gender: Male Location: Western Sydney Posted 15/11/15 03:16 AM Author Share Posted 15/11/15 03:16 AM Had a productive weekend, fitted a set of 4 pot front Brembos and PBR upgrade rears. Massive difference, should have been done before any power mods.Finally got around to moving the catch can, moved it under the intake manifold. Then fitted a new overflow bottle using the bracket I had the catch can in.Pretty happy with the ute now, will be great once I get rid of the solid mounts next week. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/3/#findComment-1570129 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 10m 7d Gender: Male Location: Adelaide Posted 15/11/15 04:13 AM Share Posted 15/11/15 04:13 AM Still running jonnys cooler or just the pipes Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/3/#findComment-1570133 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 1m 12d Gender: Male Location: Western Sydney Posted 15/11/15 04:33 AM Author Share Posted 15/11/15 04:33 AM Still got the Tig cooler, best there is. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/3/#findComment-1570135 Share on other sites More sharing options...
