BAXRTUTE Gold Donating Members 2,639 Member For: 9y 2m Posted 07/09/16 08:56 AM Share Posted 07/09/16 08:56 AM Ever since kiefy got his hot water back on this site has gone to shight, get out of the bath ffs kiefy.. u need to just take it that your a smelly hamster Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/28/#findComment-1610729 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,561 Member For: 17y 2m 9d Gender: Male Location: Melbourne Posted 07/09/16 09:59 AM Share Posted 07/09/16 09:59 AM Haha guys. It's probably broken... I'll fix it... Eventually... 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/28/#findComment-1610740 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 5m 24d Gender: Male Location: Melbourne Posted 07/09/16 11:07 AM Share Posted 07/09/16 11:07 AM easier just to ban keif Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/28/#findComment-1610762 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 1m 17d Gender: Male Location: Western Sydney Posted 08/03/17 12:56 AM Author Share Posted 08/03/17 12:56 AM So I've decided I want wider rears, which means wider front to keep it reasonable balanced. Plan is to have it sorted by AFD in July.As the pan hard bar causes a fair bit of lateral movement I'm lowering it again and fitting stiffer front and rear springs. Specifically a 12kg front and a 7 kg rear spring. Shockworks standard fg coil over spring is a 9kg and the 5 link currently has a 300lb/in tapered, equivalent to a 3.5kg (tapered) to 5kg main spring.This is the cheapest option rather than having the rear end modified again, as nice as a watts linkage setup would be I can't justify any more rear end expenses unless its a diff rebuild. Wheels will be rota grid variants with 18x10 fronts and 18x12 rears, 285/35r18 and 335/30r18 respectively. Tyres will likely be nitro nt555 front and nt555r rear as they have matching tread patterns and apparently last a decent while on the street. The front and rear guards will need rolling. Aside from this its a matter of getting the correct offsets which are available off the shelf with rotas and also fitting a modified set of upper control arm brackets to add a few degrees of negative camber. Thanks to Nelsonian101 for the tips on fitting the 285s up front.The only issue is to go black or silver with the wheels? Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/28/#findComment-1633723 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,561 Member For: 17y 2m 9d Gender: Male Location: Melbourne Posted 08/03/17 12:59 AM Share Posted 08/03/17 12:59 AM definitely silver rims Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/28/#findComment-1633724 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 1m 17d Gender: Male Location: Western Sydney Posted 08/03/17 01:05 AM Author Share Posted 08/03/17 01:05 AM Was thinking that. Also I'm gonna have to get rid of the under drive kit at some point as the steering already gets heavy at low rpm. Fun job that one. Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/28/#findComment-1633726 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 5m 24d Gender: Male Location: Melbourne Posted 08/03/17 05:37 AM Share Posted 08/03/17 05:37 AM yer silveer should look good, gonna look fat from the rear. Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/28/#findComment-1633741 Share on other sites More sharing options...
samhouston Donating Members 153 Member For: 16y 1m 10d Gender: Male Location: Brisbane Posted 12/03/17 02:20 PM Share Posted 12/03/17 02:20 PM What offsets are you going to go with the new wheels? The set up in the rear of this is unreal, great job! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/28/#findComment-1634238 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 1m 17d Gender: Male Location: Western Sydney Posted 12/03/17 07:04 PM Author Share Posted 12/03/17 07:04 PM Fronts will be Rota P45R2 18x10 +12.Rears will be Rota P45R3 18x12 +20.Just waiting on conformation that the fronts will clear brembos, the Rota dealer sounded confident they would clear but I want to be 100% sure. Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/28/#findComment-1634240 Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 13y 3m 5d Gender: Male Location: Perth Posted 12/03/17 09:47 PM Share Posted 12/03/17 09:47 PM On 08/03/2017 at 12:59 AM, k31th said: definitely silver rims Expand On 08/03/2017 at 5:37 AM, Ford Freak said: yer silveer should look good, gonna look fat from the rear. Expand ^WTS. Silver ftw! Link to comment https://www.fordxr6turbo.com/forum/topic/90530-my-2010-xr50t-ute/page/28/#findComment-1634242 Share on other sites More sharing options...
