  • Carnage on the Garage Floor
  • Member For: 14y 11m 11d
My stock balancer was still ok but...my tuner really dislikes them when making a bit of power. Mine does feel a little bit more responsive with the powerbond unit fitted too. Good work taking it on yourself.
Quick tip for those trying to crack the bolt. I don't know which relay it was but Bionic the clever bugger used the starter to crack it with a long extension against the passenger side rail as he'd done another balancer in the morning and broke his power bar in the process - doh! I held the socket and extension in place the he jumped the starter from the fuse box a couple of times and it undid it for us - win! No starter out or lock the crank required. Sorry I didn't get this info to you beforehand as it would've saved you some punish.
  • XR50T
  • Member For: 11y 11m 21d
All good mate, I had thought about that but wasn't keen on tightening the bolt the same way. By pulling out the starter I was able to tighten the bolt no probs.
  • 4 weeks later...
  • XR50T
Ordered a coil over and adjustable rear damper kit from Shockworks last week. It arrived today, top looking bit of kit and as a lot of others have said Brett is a top bloke to deal with.
Going to fit them this weekend to see how well it all goes with the stock bushes as they'll be getting changed soon enough.
  • XR50T
Shockworks all in and fitted a set of Calvert Racing Caltracs
Shockworks are pretty easy to install, undo a few nuts and bolts swear a bit then put the nuts/bolts back.
The Caltracs come with a solid aluminium bush for the front eye in the leaf springs. Left in the freezer overnight and it pressed in fairly easily. Hardest part was getting the stock eye bush out. Hole saw + Map gas FTW.
The rest was pretty simple. Bolt it all up, get the wheels on, and set the preload when it was on the floor.
Since I've moved the header tank and ECU adjusting the front dampers is a breeze.
Only issue is the front hangar does hang fairly low, might move it to the top hole if it causes problems.
And its RSpec now..........
  • Like 2
  • 2 weeks later...
  • 4 weeks later...
  • XR50T
Got a bit done over the last few weeks. Fitted the technico billet tail shaft coupling a while back and its held up so far, the washers they now supply with it seem to do the job.
The only noticable change in NVH is you can hear when the gearbox loads/unloads any driveline slack when under 10-20km.
Leveled out the ride height a bit. Raised the front coil overs and lowered the rear a bit by removing the helper leaf springs. Also cut the front caltrac bracket to give some more clearance.
Then added some more black to the bay.
  • 1 month later...
  • XR50T
Got my hands on a Jonny Tig cooler kit about a month ago. Its a top bit of kit, quality tube and fin cooler with a 3" hot and cold side.
Does the job really well and weighs a lot less than the PW stage 3.
Side by side
Won't put up a comparison between the two as ambient temp was pretty different on test days. But its not a step back by any means.
  • Like 5
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 22d
In your opinion how much less does the jonny tig cooler weigh vs the PW3 ?
