PhilMeUp Member 1,045 Member For: 16y 6m 14d Gender: Male Location: Perth, Western Australia Posted 06/08/15 02:59 PM Author Share Posted 06/08/15 02:59 PM Updates? Running sweet & rego'd ? Hopefully we will see a flood of updates?Haven’t done anything lately - have pretty much hit the point where I now need the input of someone who has more skills and resources than I do. I was supposed to get a phone call back from someone last week, but it didn’t eventuate. Things that I currently need help with - know anyone? - Figure out how to get it through a licensing inspection - use standard dump pipe, cat and injectors?- Diagnostic engine codes - currently getting P1132, was previously getting P0121, P2110 and P2135- Service/flush transmission fluid- Fit PWR heat exchanger- Fit Earl’s turbo oil line kit- Discussion of air filter location - whether it’s suitable behind the front bumper/RH headlight Link to comment Share on other sites More sharing options...
bamk2f6tornado Bronze Donating Members 777 Member For: 11y 1m 27d Gender: Male Location: Rockhampton Qld Posted 06/08/15 08:05 PM Share Posted 06/08/15 08:05 PM Had 0121 and 2110 when my tps was rooted if that helpsSent from my SM-G920I using Tapatalk Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 2m 10d Gender: Male Location: Brisbane Posted 09/08/15 06:32 AM Share Posted 09/08/15 06:32 AM (edited) Phil, you may have to use some gear of your other tornado to get through licencing, pita I know. Not sure how it is in your state.Would think your capable of the tranny service heat exchanger job. I think Ralph has a gulf western guy? Was gonna hit him up about that as well.Turbo oil filter is a pretty simple job. Bit fiddly. The part that annoyed me the most was removing the old hard line. Removing thermos probably would have helped.Behind the bar is a sh*t place for an air filter. Edited 09/08/15 06:38 AM by barnz 1 Link to comment Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 2m 5d Gender: Male Location: Perth Posted 13/08/15 02:35 AM Share Posted 13/08/15 02:35 AM (edited) That's a decent list.I have a bunch of standard BF turbo items, like dump etc, that I'll do super cheap for you if keen Edited 13/08/15 02:35 AM by Tocchi Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 7d Gender: Male Location: Perth Posted 13/08/15 03:13 AM Share Posted 13/08/15 03:13 AM flooded with offers for parts. Gotta be happy with that 1 Link to comment Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 6m 14d Gender: Male Location: Perth, Western Australia Posted 13/08/15 09:47 PM Author Share Posted 13/08/15 09:47 PM That's a decent list.I have a bunch of standard BF turbo items, like dump etc, that I'll do super cheap for you if keen Done. Let me know when you're in Perth. There shall be some wheeling and dealing!flooded with offers for parts. Gotta be happy with thatYep. I'm getting the hang of what I need to do to get this thing through a rego inspection.Bit of a learning process for me... what can be engineered/certified, and what can't (ie need to put standard stuff on just for the inspection). It's all about the 5 gas test. Modify the exhaust in any way and the car needs to pass a 5 gas test - it will fail with the aftermarket cat. I need to avoid the 5 gas test by putting on a standard dump pipe and cat for the rego inspection. I've got an automotive engineer onto it to certify the plenum intake and pod filter. Helpful guy.Problem is that he also wants to cover the Bilsten shocks that I put on. He's measured the height of the car (ie at the roof), and it's 105mm lower than it should be. Got me stuffed - it's got almost new rear leaf springs and new Lovells XR8 springs on the front.The distance from the centre of each wheel to the wheel arch is also way too short. Again, got me stuffed, I've got this thing set to original Tornado height. He's looking for some other measurements that he can use. I haven't done anything with this car since replacing the suspension a few weeks ago (sick of working on cars). Time to get back into it. Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 2m 10d Gender: Male Location: Brisbane Posted 13/08/15 10:30 PM Share Posted 13/08/15 10:30 PM 105mm! The I <3 Bananas? He has to be wrong, is he using RTV specs? Link to comment Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 6m 14d Gender: Male Location: Perth, Western Australia Posted 13/08/15 11:03 PM Author Share Posted 13/08/15 11:03 PM 105mm! The I <3 Bananas ? He has to be wrong, is he using RTV specs?He did a rough measurement with a tape measure at 1410mm. It's meant to be 1515mm, but the car is allowed to be 50mm lower. That still leaves me 65mm too low.I'm wondering if Ford's specified height includes the optional sports bars in the back of the ute tray. They go a little bit higher than the roof. Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 2m 10d Gender: Male Location: Brisbane Posted 13/08/15 11:45 PM Share Posted 13/08/15 11:45 PM (edited) Well in qld we don't measure the height of car from the ground to the highest point lol wtf is that? Hub to guard or ground clearance method which is often from the exhaust or whatever is lowest. Did he take his measurement off a perfectly level surface? This is why HTG is most accurate...as long as that measurement isn't x amount lower than factory and you don't have a rice spec exhaust it should be all gravy Edited 13/08/15 11:47 PM by barnz Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,181 Member For: 16y 9m 20d Gender: Male Location: Melbourne Posted 13/08/15 11:50 PM Share Posted 13/08/15 11:50 PM HTG is all well and good, but you can have a "low" car with plenty of ground clearance, if you have different suspension components to stock.Ground clearance on a flat and level surface should be the only way accurate way to measure it.Overall height should only matter for "high" vehicles (trucks/buses etc). Regular road cars aren't going to be causing any issues with their overall height (barring extreme circumstances).With regard to your situation, Phil, it seems like the guy has the wrong figures - there's absolutely no way your car is >100mm lower than stock height after you put the stock suspension back in. Link to comment Share on other sites More sharing options...
