Help: Something's Killing My Battery!
"Captain Retard"
  • Member For: 17y 1m 20d
I think you have an aftermarket alarm or immobiliser installed...
And that button will be a reset or backup or some other strange operation
Pull the lower part of the dash off and trace that button, might find another fuse somewhere
  • Member For: 10y 8m 8d
Yeah I'll have a go tomorrow and leave the battery on trickle charge overnight.
Wilko are you sure about the 30-50 (0.03-0.05 amps)milliamps or is it 300-500 (0.3-0.5 amps) milliamps draw?
Because I have about 300 milliamps (0.3 amps) draw.
Well a 400ma current being drawn is the same as a 5w globe glowing constantly
Should be aiming for less than 0.1amp (100 milliamps)
I'll go out and test my car and see what I get
220 milliamps
So was higher than I thought...
but my brain is still grinding it's gears, trying to think of a solution for you
Did you trace that little red button yet ?
Thanks mate your a champ!
No I didn't trace the button yet, I've had the battery on a trickle charge for the last 24hrs.
I will wait until the battery is back to full strength then get stuck into it.
On nightshifts atm.
My plan is to trace the red button wires and find out what that alarm inside the car is connected to, will do it sometime this week.
Thanks again Wilko
