masda74 To Loud Gold Donating Members 4,112 Member For: 13y 3m 10d Gender: Male Location: WA, Perth Posted 29/04/15 01:05 AM Share Posted 29/04/15 01:05 AM Rollex, I would say come for a drive in my car to compare, but I know you are not in Perth.All manuals will do this especially if you have changed the diff bushes.I have the nolothane bushes in there and if you don't caress her, guess what.It is all about driving styles mate.If you don't give it a bit of load and disengage then you will get that clunk from the drive line.I am use to it already and always get around it.Two solutions really:Drive it like it is stolenKeep foot on accelerator a bit while disengaging. Link to comment Share on other sites More sharing options...
rollex Member 683 Member For: 10y 9m 5d Gender: Male Location: Australia Posted 29/04/15 01:09 AM Author Share Posted 29/04/15 01:09 AM So the tougher bushes are what causes it? I guess that is still better than using the stock ones and having them flog out every 2 seconds. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 18d Gender: Male Location: Perth Posted 29/04/15 01:13 AM Share Posted 29/04/15 01:13 AM Roll on Roll offRoll on the the throttle and off the clutch when taking off, Roll on the clutch and off the throttle when preparing to change and vice versa post change. Link to comment Share on other sites More sharing options...
rollex Member 683 Member For: 10y 9m 5d Gender: Male Location: Australia Posted 29/04/15 01:33 AM Author Share Posted 29/04/15 01:33 AM Increasing the throttle hang would probably help as well, I'm guessing you can change this in the tune fairly easily? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 18d Gender: Male Location: Perth Posted 29/04/15 01:40 AM Share Posted 29/04/15 01:40 AM Yes it does and Yes you can.Edit: Personally I preferred to train myself to drive around it but the throttle dashpot decay table can be altered to improve the situation.EDIT EDIT:I can't believe I missed this.....Roll on Roll off Rollex 2 Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 3m 10d Gender: Male Location: WA, Perth Posted 29/04/15 02:16 AM Share Posted 29/04/15 02:16 AM hahahahaha gold. you have me in tears from laughter.Roll off Rolex!!!change of name? Link to comment Share on other sites More sharing options...
PAH Donating Members 361 Member For: 16y 1m 22d Gender: Male Posted 02/05/15 10:11 PM Share Posted 02/05/15 10:11 PM (edited) Guys. Mal Wood in Warwick Qld adjusted the diff and gearbox in mine a few years back and it's bean much better ever since. I mentioned this to Spiro at Autotech and I think he said that he could have done the work for me in Sydney.In the hotter summer months, I still get a bit of rollover noise in neutral with my foot off the clutch. Push the clutch in and the noise disappears. That noise disappears in the cooler months. Maybe a trans oil cooler would eliminate the noise, but the gearbox shifts more smoothly when its warm. If my memory is correct, Mal Wood recommends Caltex Trans Max Z synthetic fluid for the gear box. He also fitted a remote clutch bleed line for me.PAH Edited 02/05/15 10:14 PM by PAH Link to comment Share on other sites More sharing options...
rollex Member 683 Member For: 10y 9m 5d Gender: Male Location: Australia Posted 03/05/15 02:16 AM Author Share Posted 03/05/15 02:16 AM Are you able to find out exactly what was "adjusted" ? Link to comment Share on other sites More sharing options...
Z2TT Member 714 Member For: 12y 9m 14d Posted 17/05/15 03:43 PM Share Posted 17/05/15 03:43 PM (edited) Can you tune the off throttle to disengage slowly so it's in the tune, as otherwise I have learn't just to let off my throttle slowly and it's annoying. The FG is almost a perfect car this is the only let down if somebody could design a different subframe setup I would buy it.How do you avoid the clunk, keep your foot plantedit's like the joke how do you avoid a hangover, keep drinking. Edited 17/05/15 03:46 PM by Z2TT Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 18d Gender: Male Location: Perth Posted 17/05/15 10:34 PM Share Posted 17/05/15 10:34 PM Boris independent Motorsport have redesigned the rear diff mount arrangement and have a very good solution. Link to comment Share on other sites More sharing options...
