Senna22 New Member 1 Member For: 10y 1m 5d Posted 25/04/15 01:13 AM Share Posted 25/04/15 01:13 AM Hey guys, just recently purchased an XR6 T. Don't know much about it but learning ... Everything was working fine until recently. When I drive the car, everything is normal except when I push it over 2 RPM's! The normal whistle sound that it makes has disappeared, and the sound that it makes is "chuuu". I feel it losing power and feels like it might be choking in a way. Ive replaced the paper air filter with a KNN Filter three weeks ago. I've checked all the pipes to make sure they're not loose, I've also cleaned the carbonator, and when I opened to see the turbo, it had a drop of oil or fuel there just outside the fan. Is that normal? Think the sound came about when I went to a dodgy petrol station, I put in premium unleaded but since then it has been working like crap, I've refuelled twice since then with 98. But the sound is still there.Maybe il need to change the fuel filter.What could be the issue, has it happened to anyone before?Any help would be appreciated, thanks Senna Link to comment https://www.fordxr6turbo.com/forum/topic/90427-turbo-whistle-sound-gone-replaced-by-chuuuu-sound-help33/ Share on other sites More sharing options...
stubbietubbie Filthy weeb Member 1,870 Member For: 12y 3m 14d Gender: Male Posted 25/04/15 03:21 AM Share Posted 25/04/15 03:21 AM On 25/04/2015 at 1:13 AM, Senna22 said: When I drive the car, everything is normal except when I push it over 2 RPM's!Yeah, that's because the engine's starting to work.(Sorry, had to jump on that!) Link to comment https://www.fordxr6turbo.com/forum/topic/90427-turbo-whistle-sound-gone-replaced-by-chuuuu-sound-help33/#findComment-1541527 Share on other sites More sharing options...
loop it Member 62 Member For: 10y 3m 5d Posted 27/04/15 03:28 AM Share Posted 27/04/15 03:28 AM pull the intake off and see if you can feel excessive shaft play Link to comment https://www.fordxr6turbo.com/forum/topic/90427-turbo-whistle-sound-gone-replaced-by-chuuuu-sound-help33/#findComment-1541811 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 10m 7d Gender: Male Location: Maryborough Qld Posted 04/05/15 09:24 AM Share Posted 04/05/15 09:24 AM Boost leak.... Link to comment https://www.fordxr6turbo.com/forum/topic/90427-turbo-whistle-sound-gone-replaced-by-chuuuu-sound-help33/#findComment-1543021 Share on other sites More sharing options...
Zerosignal Phantom Menace Donating Members 232 Member For: 14y 9m 20d Gender: Male Posted 14/05/15 01:56 PM Share Posted 14/05/15 01:56 PM Check the hose to your throttle body, likely split. Link to comment https://www.fordxr6turbo.com/forum/topic/90427-turbo-whistle-sound-gone-replaced-by-chuuuu-sound-help33/#findComment-1544431 Share on other sites More sharing options...
Northerly1 New Member 16 Member For: 9y 11m 13d Posted 04/07/15 08:22 AM Share Posted 04/07/15 08:22 AM Gday mate, im same as you , mine is fg mk 2 and 70ks it is like a whiring sound, does that sound like your noise, sort of? Link to comment https://www.fordxr6turbo.com/forum/topic/90427-turbo-whistle-sound-gone-replaced-by-chuuuu-sound-help33/#findComment-1551701 Share on other sites More sharing options...
imc77 New Member 9 Member For: 9y 11m 19d Posted 15/07/15 01:12 AM Share Posted 15/07/15 01:12 AM Did it sound like a vacuum sound?If so, I had the same issue.. I went to CGR Racing / Narrabeen.. they reset the computer and the boost come back.they advised the scan read P1228 (underboost). he cleared the codes and boost flowed through no probs. suspect the actuator flap was stuck open.the following day I had another drive.. was back to the vacuum sound.My scanner still showing the P1000 reading.. unsure if related or not.going back this week.. will let you know how it goes. Link to comment https://www.fordxr6turbo.com/forum/topic/90427-turbo-whistle-sound-gone-replaced-by-chuuuu-sound-help33/#findComment-1553903 Share on other sites More sharing options...
luke187 Member 297 Member For: 11y 5m 23d Posted 22/07/15 07:12 AM Share Posted 22/07/15 07:12 AM (edited) You sure its not your bov leaking/failed or the vacuum line to it? Edited 22/07/15 07:13 AM by luke187 Link to comment https://www.fordxr6turbo.com/forum/topic/90427-turbo-whistle-sound-gone-replaced-by-chuuuu-sound-help33/#findComment-1555018 Share on other sites More sharing options...
imc77 New Member 9 Member For: 9y 11m 19d Posted 30/07/15 02:09 AM Share Posted 30/07/15 02:09 AM got it sorted. the actuator alignment was way out and needed to be refitted.. no leaks etc. its back to normal now. Link to comment https://www.fordxr6turbo.com/forum/topic/90427-turbo-whistle-sound-gone-replaced-by-chuuuu-sound-help33/#findComment-1555979 Share on other sites More sharing options...
