  • Member For: 14y 1m 7d
So story goes, had just started driving home (8-10km drive) and noticed the speedo wasn't working (km/hr), then when I was nearly home the etc light came on and it went into limp mode, luckily I was only 1km from home, so I just limped home.
Once home I turned it off, locked it, then unlocked it and started it, it started fine, I reversed down the driveway and drove back in and everything is working fine again.
Does anyone know what's going on?
Will be seeing a mechanic 2moro, last service was only 600kms ago, battery and alternator replaced about 5000kms ago
It's a bf2 f6 ute.
Any help will be mu hoy appreciated
https://www.fordxr6turbo.com/forum/topic/90421-help-needed-electrical/
  • Member For: 11y 5m 2d
Sounds kinda like the abs module has shat itself. Was it just the speedo not working or entire dash.
Do u have the facilities to scan for codes?
  • 10 months later...
  • Bronze Donating Members
  • Member For: 11y 9m 21d
BF F6 ute here, did some strange things with the speedo for a while. Intermittent; but I think I found a loose earth and after Ive torqued it back up everything seems good.  Can't say that was the exact cause however, I think mine was a canbus fault as it didnt throw a code.
