phoonf6 New Member 8 Member For: 11y 9m 14d Posted 02/09/15 07:17 AM Share Posted 02/09/15 07:17 AM And whats the actual difference in the pot as the photo on the website looks essentially like a standard one with a pump dropped in it for the ba/bf Sent from my iPhone using Tapatalk Link to comment https://www.fordxr6turbo.com/forum/topic/90399-fuel-pump-upgrade/page/3/#findComment-1560224 Share on other sites More sharing options...
KPM Motorsport Member 968 Member For: 19y 8m 5d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 04/09/15 11:58 PM Share Posted 04/09/15 11:58 PM (edited) The fuel system we supply are guaranteed NO surge for all models BA-FGX.It is not only the upgraded pump and cradle that ensures this , but the system operating a s a whole.eg Larger pump flows 400lph therefore to ensure correct return flow and pressure you need a higher flowing pressure regulator to match. eg 400lph return flow reg.Larger pump draws more current, therefore you need heavier wiring to ensure correct voltage supply for proper operation.If all the items are not matched , you will have a system that may flow more, however with high pressures and poor return flow therefore increasing the current required on standard wiring.This is what causes surge!The misconception of an intank system causing surge is absolute rubbish, due to the many being improperly set up .Al our systems are rated at the power delivery they can support.eg700hp1000hp1500hpThey are then engineered as a kit to ensure correct delivery with correct associated components.This ensure hassle free fitment, correct cool dense fuel delivery at correct pressures for maximum performance.Happy to chat if you have any further questions.08 82999 998David Edited 05/09/15 12:00 AM by KPM Motorsport 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90399-fuel-pump-upgrade/page/3/#findComment-1560548 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 10m 22d Gender: Male Location: Adelaide Posted 05/09/15 01:11 AM Share Posted 05/09/15 01:11 AM How does the 1000hp+ fuel setups go with standard fuel lines. Do the fuel lines need to be upgraded aswell or are they good to go. Link to comment https://www.fordxr6turbo.com/forum/topic/90399-fuel-pump-upgrade/page/3/#findComment-1560554 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 1m 1d Gender: Male Location: @ my laptop Posted 05/09/15 02:17 AM Share Posted 05/09/15 02:17 AM why doesn't the swirl pot sit low in the tank, it sits on the bottom 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90399-fuel-pump-upgrade/page/3/#findComment-1560563 Share on other sites More sharing options...
KPM Motorsport Member 968 Member For: 19y 8m 5d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 05/09/15 11:45 PM Share Posted 05/09/15 11:45 PM Yes. The standard fuel lines flow over 1000lph , The 1000hp system flows 600lph.Standard fuel lines and fuel rails are perfect even on the 1500hp system 2 Link to comment https://www.fordxr6turbo.com/forum/topic/90399-fuel-pump-upgrade/page/3/#findComment-1560669 Share on other sites More sharing options...
dansa New Member 1 Member For: 9y 6m 28d Posted 05/12/15 01:17 PM Share Posted 05/12/15 01:17 PM How much current does the Walbro 460 draw? Link to comment https://www.fordxr6turbo.com/forum/topic/90399-fuel-pump-upgrade/page/3/#findComment-1572917 Share on other sites More sharing options...
