Fuel Pump Voltage Booster/controller
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 8m 14d
If you take that KPM intank in anyway shape or form past its "intended" listed use expect no acceptance to fault if it falls over and you end up wearing the cost of not only the unit but what it damages
This will be fair to say about most fuel systems
Unless, the manufacturer states "clearly" that said unit is safe to "overrun" or is within its rated voltage
  • Moar Powar Babeh
  • Member For: 19y 4m 22d
I don't know of too many pump manufacturers that don't rate (and provide flow figures) for their pumps up to 18v at least?
I'm no spark-o-logist but ohms law would suggest a higher voltage to the pump would result in reduced current draw?
  • I <3 Floods
  • Member For: 13y 6m 13d
That's my understanding. Power = Voltage x Current
But if you want the unit to operate at a higher capacity you want to boost the voltage and maintain the current therefor increasing power.
I'm no electro-zappy-stuff-gineer but I think that's the concept.
in this aftermarket world get it in writing first !!!
Everything else after that fact
Yes true luke but don't take that as acceptiable as some manufactures will use that as an "out" when said product fails
It's like when I say I have used a 044 on E85 well past the 500 "rated" hrs and it was fine ;)
Always use a product within it's stated opperating limits or wear the effects if any
Just sayn
  • Member For: 12y 7m 7d
Geez your onto it fifty-one op comes on asking about voltage boosters and your first response is don't bother and your second is ask your tuner.
Perhaps Op has asked his tuner and the tuner has suggested he seek experience from a larger knowledge base?
I don't understand what's going on with this place of late with members steering other members away when they are asking legit questions.
http://aeromotiveinc.com/products-page/accessories-electronics/fuel-pump-speed-controller/
http://www.kennebell.net/KBWebsite/Accessories_pg/Boost%20A%20Pump/layouts/boostapump.htm
Total agree with this statement!
  • Member For: 18y 8m 20d
I was just doing some more research, when I found this. Very interesting read...
So, I was having a bucking/stuttering problem on the top end/peak torque of my road dyno pulls. This was not mild at all, it was violent and felt like fuel cut.
I narrowed it down to the 460 pump I installed during my motor build. Let me tell you what I personally found to solve the problems I was having so that you too may take this into consideration when installing one of these awesome pumps.
The initial way I had this setup was by using the stock hanger setup and the stock wiring. This did not work at all. Every WOT run I would do ended in a bucking stuttering fuel cut and letting off the accelerator.
Thinking that it was a power issue I ran a #10 wire and a #10 ground. I ran the power to a 30 amp relay, used the original power/ground that went to the stock fuel pump to power the coil in the relay, and ran the #10 ground directly to the pump itself. Took it out for a drive and had the same problems. I was now thinking I had a bad fuel pump. I started searching the internet for answers and came across numerous threads with blown fuel pump controllers/electronics when using a walbro 400/460 pump.
The reason the fuel pump controllers were burning up was from the simple fact that if the body of the fuel pump makes contact with the hanger or any other type of ground the fuel pump controller cannot use PWM on the ground wire from the ecu to control the flow of the pump (33%,66% or 100%). The walbro 460/400 pumps have an internal connection from the wiring ground to the body of the pump. Most other pumps do not have this or they fit into the hanger so that no contact from the hanger induces a faulty ground signal sent back to the ecu for controlling the flow of the fuel pump. Also keep in mind that the 460 pump will pull a whopping 19 amps @13.5 volts and 80 psi. The stock fuel pump controller is not up to this task at all.
This is what I did to eliminate the problem 100%. I removed the fuel pump controller in its entirety. I disabled the p0230 FUEL PUMP CONTROLLER code from the ecu. I then took the harness that goes from the passenger side of the trunk and made a jumper wire from the stock fuel pump relay that normally powers the fuel pump controller (black yellow wire) to the original fuel pump power wire (black orange wire). I made a good solid ground in the trunk and connected that to the original fuel pumps ground wire (black white wire). These jumpers would now end up turning the 30 amp relay on/off when the ignition is turned on. The pump will run at 100% all of the time now so I recommend an aftermarket FPR. I am running a sard unit and it is working flawless for me.
I chased my tail for 2 weeks trying to figure this out. The 2005 STI pulls hard all the way to redline now and I can maintain an afr of 10.5-1 if I would like. Learn from my mistakes, the stock fuel pump controller does not provide the means to control this pump without issues unless rewired or eliminated from the equation.
Edited by HI PSI
  • Moar Powar Babeh
Good info, earthed body is probably a spark/fire risk mitigation tactic due to the aftermarket applications for the pump.
I've mentioned it a few times, I'm running a fuel lab pump and electronic reg.
Pump speeds is controlled based on pressure in the rail. I've had zero issues with the system and it's quiet and efficient.
Hi psi I would go with the pmw control of the aeromotive unit. It will allow you to reduce pump speed at low demand and reduce load on the return side of the system.
I'm keen to hear which way you go and the results.
  • Member For: 11y 1m 23d
Why did they do this? Don't the majority of controllers modulate the flow using the ground wire? Do they just expect the mount be insulated?
