Monit0r New Member 2 Member For: 9y 10m 26d Gender: Male Posted 11/04/15 11:31 PM Share Posted 11/04/15 11:31 PM G'day,Can anyone provide me with a step by step for removing the stock turbo and installing a GTX3582R, with reference to changing oil lines and necessary mods that need to be made in the upgrade?Can you simply replace the stock turbo with a GTX3582R?Cheers Link to comment Share on other sites More sharing options...
julesk_1972 Member 267 Member For: 12y 7m 11d Gender: Male Location: Perth Posted 11/04/15 11:41 PM Share Posted 11/04/15 11:41 PM Are you sure you want to do this yourself?Your questions imply zero research. Link to comment Share on other sites More sharing options...
Monit0r New Member 2 Member For: 9y 10m 26d Gender: Male Posted 12/04/15 02:22 AM Author Share Posted 12/04/15 02:22 AM This is part of my research. Ford quoted $6k for a failed wastegate. I am thinking about upgrading instead of simply replacing. From what I have read the GTX3582R is similar to the GT3582R. Looking at how to change a turbo, it seems like I could do this myself and save $176/hour labour. The information I am chasing is to what extent do I have to modify other components of the engine to handle the increase in power and fuel consumption in the short term? In addition given the GTX is slightly larger, is it necessary to replace the oil lines? I can only find conflicting information on this.Thank you in advance for your help Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 7m 3d Gender: Male Location: Adelaide Posted 12/04/15 02:43 AM Share Posted 12/04/15 02:43 AM Xr6 or f6.2.5 to 3 hour job. Link to comment Share on other sites More sharing options...
sixman Donating Members 601 Member For: 20y 7m 14d Gender: Male Location: Hills District, NSW Posted 12/04/15 03:22 AM Share Posted 12/04/15 03:22 AM 6k for turbo and exhaust housing? Damn!If you upgrade the turbo to a gtx you will need a tune/xcal4, injectors etc. Can add up pretty quickly.You could source a second hand gt as a direct replacement pretty cheaply. 2 Link to comment Share on other sites More sharing options...
