Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 11m 3d Gender: Male Location: Adelaide Posted 22/04/15 08:19 AM Share Posted 22/04/15 08:19 AM Just trash it luke it gets warm quick. No milkshake. Link to comment https://www.fordxr6turbo.com/forum/topic/90351-checking-zf-oil-for-coolant/page/6/#findComment-1541012 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 15d Gender: Male Location: Perth Posted 22/04/15 08:20 AM Share Posted 22/04/15 08:20 AM Pwr No milkshake. No flare either. Link to comment https://www.fordxr6turbo.com/forum/topic/90351-checking-zf-oil-for-coolant/page/6/#findComment-1541013 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 11m 3d Gender: Male Location: Adelaide Posted 22/04/15 08:23 AM Share Posted 22/04/15 08:23 AM Argue with jet. He did it. Lol Link to comment https://www.fordxr6turbo.com/forum/topic/90351-checking-zf-oil-for-coolant/page/6/#findComment-1541015 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 15d Gender: Male Location: Perth Posted 22/04/15 08:28 AM Share Posted 22/04/15 08:28 AM Who's arguing? You and Jet are both saying there's not negative effect from the air to air but now your saying it flares when cold?Have you held a PWR cooler in your hand and compared it to the stock cooler? The sheer weight difference would suggest to most people it's highly unlikely that a comparison in quality or likelihood of failure can be made. Add to that move from the high vibration mounting area of the stock cooler to the new location or the PWR and it become even more unlikely the cooler will fail. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90351-checking-zf-oil-for-coolant/page/6/#findComment-1541017 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 11m 3d Gender: Male Location: Adelaide Posted 22/04/15 08:37 AM Share Posted 22/04/15 08:37 AM Ill leave it for now. If the box goes its an excuse to get it built I guess Link to comment https://www.fordxr6turbo.com/forum/topic/90351-checking-zf-oil-for-coolant/page/6/#findComment-1541020 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 11m 3d Gender: Male Location: Adelaide Posted 22/04/15 08:49 AM Share Posted 22/04/15 08:49 AM One question. Cold you run a pwr and oil to air together. I think I have read somewhere if you giving the car a thrashing for a long time the pwr can over heat the trans or something. With a pwr and oil to air it could prevent the chance of overheating and the pwr could help the oil to air on cold day? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90351-checking-zf-oil-for-coolant/page/6/#findComment-1541023 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 8d Gender: Male Location: Adelaide Posted 22/04/15 09:47 AM Share Posted 22/04/15 09:47 AM (edited) Fact is at least one wizz bang PWR cooler has failed and milkshaked a ZF Fact is we have NONE Done over 20 zf air coolers and this is the first time iam hearning of anything in a negative, I would be keen to check fluid levels/fluid condition/filter flow then clutch slip in the zf before heading towards the air cooler The only time an increase of "thump" has happened was when a ugly zf calibration was tuned into the box and even then we were expecting something to show up If you are going to make an informed decision you must do your own testing to back up a pro or a con Said it before it did SFA negitive to what the data said "might" happen XA - listen to what I said before, the cooler/lines are placed in a particular location for a reason.... U know because we actually have done the leg work to back up what we were doing not just pot luck guess work Cheers thanks ta Edited 22/04/15 09:49 AM by Wombat Bellend Link to comment https://www.fordxr6turbo.com/forum/topic/90351-checking-zf-oil-for-coolant/page/6/#findComment-1541037 Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 2m 15d Gender: Male Posted 22/04/15 09:51 AM Share Posted 22/04/15 09:51 AM Checked my temps before posting...but I agree with above Link to comment https://www.fordxr6turbo.com/forum/topic/90351-checking-zf-oil-for-coolant/page/6/#findComment-1541038 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 8d Gender: Male Location: Adelaide Posted 22/04/15 09:58 AM Share Posted 22/04/15 09:58 AM Karl I struggle to understand you sometimes but makes for an interesting read regardlessWondering if XA be hating that my A6 HSV has a factory Air cooler weeeeeeeeeeeeeeeeAnd amazingly mimics the ZF heat cycle almost to the degree :D Link to comment https://www.fordxr6turbo.com/forum/topic/90351-checking-zf-oil-for-coolant/page/6/#findComment-1541042 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 15d Gender: Male Location: Perth Posted 22/04/15 10:05 AM Share Posted 22/04/15 10:05 AM Fact is at least one wizz bang PWR cooler has failed and milkshaked a ZFFact is we have NONEDone over 20 zf air coolers and this is the first time iam hearning of anything in a negative, i would be keen to check fluid levels/fluid condition/filter flow then clutch slip in the zf before heading towards the air coolerThe only time an increase of "thump" has happened was when a ugly zf calibration was tuned into the box and even then we were expecting something to show upIf you are going to make an informed decision you must do your own testing to back up a pro or a conSaid it before it did SFA negitive to what the data said "might" happenXA - listen to what i said before, the cooler/lines are placed in a particular location for a reason.... U know because we actually have done the leg work to back up what we were doing not just pot luck guess workCheers thanks taProve your fact Link to comment https://www.fordxr6turbo.com/forum/topic/90351-checking-zf-oil-for-coolant/page/6/#findComment-1541046 Share on other sites More sharing options...
