k31th less WHY; more WOT Site Developer 29,426 Member For: 17y 12d Gender: Male Location: Melbourne Posted 04/11/20 10:10 AM Share Posted 04/11/20 10:10 AM it's not easy... but yeah Ford should be able to help you, but I doubt it will be a cheap exercise. Link to comment https://www.fordxr6turbo.com/forum/topic/90345-pbr-rear-brakes/page/2/#findComment-1700132 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 11m 30d Gender: Male Location: Canberra ACT Posted 04/11/20 10:34 AM Share Posted 04/11/20 10:34 AM The TSC is based on wheel rotation using the ABS sensors. I can't see that you would have a calibration issue after changing the brakes. I've got the same set up (322mm front with upgraded 328mm rear). I'd say it's more likely the ABS sensor was damaged or dislodged during the install. Just a guess though - someone else may have direct experience with the issue. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/90345-pbr-rear-brakes/page/2/#findComment-1700133 Share on other sites More sharing options...
MitchJ New Member 8 Member For: 4y 7m 27d Posted 08/11/20 04:43 AM Share Posted 08/11/20 04:43 AM So... it turns out the DSC issue was not with the brakes at all but with the throttle body, which was coincidentally cleaned at the same time the brakes were installed. The clue came when the CEL also turned on a day after the DSC first started playing up and the car started rough idling. Guys at Dyno-mite were very quick to sort it out, car & brakes are working perfectly now Link to comment https://www.fordxr6turbo.com/forum/topic/90345-pbr-rear-brakes/page/2/#findComment-1700241 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,426 Member For: 17y 12d Gender: Male Location: Melbourne Posted 08/11/20 04:49 AM Share Posted 08/11/20 04:49 AM what did they actually do to fix it? if the throttle body was cleaned, that doesn't usually cause anything like what you said, but OK... Link to comment https://www.fordxr6turbo.com/forum/topic/90345-pbr-rear-brakes/page/2/#findComment-1700242 Share on other sites More sharing options...
MitchJ New Member 8 Member For: 4y 7m 27d Posted 08/11/20 04:57 AM Share Posted 08/11/20 04:57 AM Think they checked if the sensor was fouled or not and then they reflashed the ECM. The throttle body on mine was particularly dirty and as I understand (correct me if I clearly don't understand) the transition of it going from being putrid to spotless was too much for the computer to re-adjust for. Link to comment https://www.fordxr6turbo.com/forum/topic/90345-pbr-rear-brakes/page/2/#findComment-1700245 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,426 Member For: 17y 12d Gender: Male Location: Melbourne Posted 08/11/20 05:05 AM Share Posted 08/11/20 05:05 AM unless it was tuned while the throttle body was significantly compromised, cleaning it wouldn't make it do that... but ok, all good... as long as your problem is sorted. Link to comment https://www.fordxr6turbo.com/forum/topic/90345-pbr-rear-brakes/page/2/#findComment-1700247 Share on other sites More sharing options...
