shaness8 Member 89 Member For: 15y 7m 9d Gender: Male Posted 09/04/15 12:53 AM Share Posted 09/04/15 12:53 AM Looks as if the run was in 3rd gear which also gives a higher reading.How many Km's on the motor. Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 3m 21d Gender: Male Location: Brisbane Posted 09/04/15 12:55 AM Share Posted 09/04/15 12:55 AM Well given your 98 tune is off by around 40ish kw which is pretty much the same as your e85 tune it seems like that power is being lost somewhere, most likely the box. Is it making a weird wharring noise? Link to comment Share on other sites More sharing options...
loop it Member 62 Member For: 10y 16d Posted 12/04/15 08:52 PM Author Share Posted 12/04/15 08:52 PM no wierd noises really I want to get a very low K fg box snd converter and put that in see how it goes I cant afford a full rebuild at this point ... Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 3m 21d Gender: Male Location: Brisbane Posted 12/04/15 09:21 PM Share Posted 12/04/15 09:21 PM (edited) Just remember to swap the mechatronics (tcm) unit over if you do that.Realistically 400rwkw(and butt loads of torque) is pretty close to the limit of a stock zf Edited 12/04/15 09:23 PM by barnz Link to comment Share on other sites More sharing options...
loop it Member 62 Member For: 10y 16d Posted 13/04/15 11:14 AM Author Share Posted 13/04/15 11:14 AM I know but im a tad poor after all the other bits Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 8m 5d Gender: Male Location: OZ Posted 13/04/15 12:20 PM Share Posted 13/04/15 12:20 PM (edited) Looks as if the run was in 3rd gear which also gives a higher reading.3rd / 4th....nothing in it bud.Also pretty easy to datalog and work out if the convertor is an issue. They should have done that if they thought there was an issue with the convertor. Edited 13/04/15 12:21 PM by IH8TOADS Link to comment Share on other sites More sharing options...
loop it Member 62 Member For: 10y 16d Posted 13/04/15 08:37 PM Author Share Posted 13/04/15 08:37 PM I called and asked but ..... "the dyno broke" and apparently my info got wiped ... not sold on that hey but autotech are a reputable shop so hopefully nothing suss here im gonna run it on another dyno before I replace converter and box then go back on both and compare Link to comment Share on other sites More sharing options...
loop it Member 62 Member For: 10y 16d Posted 13/04/15 08:40 PM Author Share Posted 13/04/15 08:40 PM im still keen on going a low K FG box would it be worth just pulling it down and putting exedy clutches in (just the 600 ones) with low Ks everything else should be ok and I dont want to rebuild the motor so 440rwkw would be the max it may ever see Link to comment Share on other sites More sharing options...
