Replace Turbo Upgrade
micktt
  • New Member
  • Member For: 10y 5m 6d
Hey looking for some advice
Had my 07 ghia for a while and time to do some mods
Have a FMIC and gt3582 turbo and external waste gate
Will this turbo work ok and what other mods are required apart from a tune
Thanks for any advice
  • Member For: 11y 9m 14d
I would chat to Monsta Torque if you haven't already? They do awesome tunes; but not sure they have done too many TT?
You may get same bad news in regards to the external gate though. Some tuners dont like it (ratter over east was saying he doesn't like tuning with them cause you cannot hear knock...or something along those lines).
Good luck either way! :)
  • Member For: 12y 6m 12d
^ just because he's running an external wastegate does not mean he's running a screamer pipe. You can still plumb it back into the exhaust system.
  • Member For: 11y 3m 19d
A turbo pcm and engine loom is really going to be necessary. It can be tuned without like a supercharged N/A conversion however the engine doesn't "know" its boosted. Which limits its potential, as does its compression ratio, rods ect. But lack of boost control is going to be the biggest issue.
Im all about a turbo ghia(bf fairmont I assume?) infact im dreaming up a fairlane specced bf wagon with turbo/zf running gear. And the ideal way I would go about achieving that would be a good wagon as a base, a wrecked fairlane donor and a wrecked bf turbo. Its the only way to ensure you have everything you need.
I would suggest if you want to do it right source a wrecked bf turbo.
Edited by barnz
  • XR50T
  • Member For: 11y 10m 10d
Pretty sure its a turbo territory barnz, considering its in the territory section.
Need more info from the OP.
Edited by OZYWALKER
