Vivasanti Member 39 Member For: 13y 4m 12d Posted 03/04/15 05:28 AM Share Posted 03/04/15 05:28 AM Hi guys,Hope you are all well and enjoying your easter?Was hoping for some suggestions into a problem im having with my 05 XR6T, I hope this is the correct forum sectionSometimes when starting the car, and then selecting gear, either "R" or "Drive" the car just lurches back and forward and revs funny like its going to stall.The "orange" engine light on the right hand side of the dash/cluster also lights when its doing this.There is nothing I can do except put the car back into "Park" turn it completely off and turn it back on and hope it doesnt do it again.I have tried resetting the ECU by leaving the battery leads off overnight and following the retuning guide, this I thought helped cause it didnt do it after restarting the car a dozen times or so - I was wrong.I will say I have never had the transmission serviced in the 2 years ive owned it, wether or not its a transmission selection problem of some kind?Has anyone heard of this problem or have any suggestions?Thanks in advance team Link to comment Share on other sites More sharing options...
Vivasanti Member 39 Member For: 13y 4m 12d Posted 03/04/15 02:22 PM Author Share Posted 03/04/15 02:22 PM After some more research I think its the "throttle fault light" maybe the TPS sensor? Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 1m 29d Gender: Male Location: WA, Perth Posted 04/04/15 01:14 AM Share Posted 04/04/15 01:14 AM If the car is tuned, you should have an xcal. I think you can use that to read fault codes from the ecu.This will tell you what your problem is. Link to comment Share on other sites More sharing options...
Vivasanti Member 39 Member For: 13y 4m 12d Posted 04/04/15 05:52 AM Author Share Posted 04/04/15 05:52 AM If the car is tuned, you should have an xcal. I think you can use that to read fault codes from the ecu.This will tell you what your problem is.Hey mate, no the car is completely stock.I have borrowed a mates ODB adapter ill use this to see if I can see anything.Cheers Link to comment Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 20y 21d Gender: Male Location: In my house Posted 04/04/15 07:08 AM Share Posted 04/04/15 07:08 AM Possible TPS issue. BA,s where renowned for it. Link to comment Share on other sites More sharing options...
Vivasanti Member 39 Member For: 13y 4m 12d Posted 07/04/15 01:57 AM Author Share Posted 07/04/15 01:57 AM (edited) Hi team just an update..Pulled the filter surrounding house off and cleaned the throttle body, it was very clean compare to the pictures of others ive seen.I can detect a slight leak or hissing comming from the manifold, does a manifold leak make much of a noise?Or is it more likely a vacuum hose, or is this just a normal sound of vacuum?Some things to note is the car runs fine once warm and idles cold at about 1500 revs but just "shakes" a little.I hooked a OBD2 to the connection and the computer has no faults or historical faults that I can find.Below are some videos of the 2 issues, they are hard to see but you might get an idea.Start problem - throttle warning light, car just jerks aroundhttps://dl.dropboxusercontent.com/u/56979135/Start%20Problem..mp4Vacuum/manifold leak?https://dl.dropboxusercontent.com/u/56979135/Possible%20leak.mp4 Edited 07/04/15 01:57 AM by Vivasanti Link to comment Share on other sites More sharing options...
