  • Member For: 10y 1m 23d
I have a bf mk2 xr6t
I bought it with 220000 ish K's and proceeded to add xforce exhaust , plazmaman 800hp I/C kit and cold air intake and air box , plaz valve springs 1000cc injectors walbro pump and got it tuned on e85 at autotech on tuesday made 353 rwkw .
Spirp seems to think I might have an aftermarket stallie but I think maybe its just flogged out ? but we both wanted more power from 18psi or there abouts
anyway the real problem I am having is full noise 3rd to 4th seems to slip hard and go to limiter slipping 3rd WONT go 4th lights on the dash come up and speedo drops out ??? back off and gear indicator drops back to 3rd and lights go off , speedo stays dropped out until cycling the ignition .
do I need a rebuild ?
thanks everyone
https://www.fordxr6turbo.com/forum/topic/90316-is-my-zf-dead/
  • Member For: 11y 4m 27d
Not shifting out of 3rd at wot is a classic dying zf symptom. However it should throw a code if it's consistently slipping. Could be oil level but at 220xxx I'd say it's the former unfortunately.
  • Carnage on the Garage Floor
  • Member For: 14y 11m 5d
With 220,000km on it then jamb boost in probably not going to end well. You might get lucky with a service but I'd say it's cactus. Can get them rebuilt now for around 4k.
Edited by Bomber
  • Member For: 17y 4m 23d
3-4 shift not working was the same in my ZF. Had it rebuilt at 210,000km.
