Lock Compartment Under Front Seat And Window Washer
MrTurboGhia
  • New Member
  • Member For: 9y 11m 2d
Hi All 2 questions here, does anyone know how to remove the bottom lock compartment under front seat? I dropped a key down the side and now have no idea how to get it back,
the other question is the front wiper washers used to squirt water out and now has stopped, the back window works fine, is there a fuse or would this be a washer motor issue
thanks heaps
  • WOT?
  • Moderating Team
  • Member For: 11y 9m 26d
1. What car? edit: just realised - territory, no idea on the compartment, sorry
2. Front and rear washers/wipers usually use different bottles - is the front one empty? - front bottle is in the engine bay (has a windscreen and wiper embossed on it)
Edited by Rab
  • New Member
ok sorry 2009 ttg under the front drivers seat is a lock box to put wallet and phone I guess if your at beach or out
so is there 2 different bottles for each wiper? the one I found at the front right is full, cant hear a sound when button pushed but if there is another bottle then I may need to find and check it
thanks
  • WOT?
  • Moderating Team
Sorry - not sure with the territory (my paj had the rear bottle in the rear door) - have you got a car manual you could check? Will show where the rear bottle is (although it's not important for your query)
If your front bottle is full then Ralph was probably on the mark with his line of questions (hope someone follows up soon)
  • Member For: 10y 1m 2d
Bottom compartment slides completly out on mine. Just pull on it hard enough and it unclips. Iv lost sooooo many items down the sides of these damned seats!
  • Member For: 16y 5m 4d
Either the washer pump is blocked with algae or it's stopped working. Very easy to fix. You can buy an aftermarket pump from Repco, etc, for around $20.
On the Falcons there is the one bottle. Cars with a rear wiper have a second water pump.
Photo guide: http://www.fordxr6turbo.com/forum/topic/89260-photo-essay-replacing-the-windscreen-washer-pump
If there's any algae or grime in the water tank then flush it out with a hose.
