Bellato Donating Members 2,713 Member For: 14y 6m 3d Posted 26/03/15 05:49 AM Share Posted 26/03/15 05:49 AM Lots of turbo options, could even come close on factory low mount and that means you save $1k on manifold plus can buy an off the shelf dump pipe rather than something custom.Fuel system, 1500cc injectors, PW surge with twin 460's, twin feed rail, fuel reg. $2500Exhaust $1500Glide and tailshaft probably $8-10kMotor depends on if you build it or not. I think the spool rebuild kit is $1100 or so.If you can build and install the motor yourself then should come close to $15-20k, but as all know budget more because sh*t goes wrong and breaks Link to comment https://www.fordxr6turbo.com/forum/topic/90282-engine-work-for-700rwhp/page/2/#findComment-1536811 Share on other sites More sharing options...
Deanochristo New Member 7 Member For: 10y 28d Posted 27/03/15 12:12 PM Author Share Posted 27/03/15 12:12 PM On 26/03/2015 at 5:49 AM, Bellato said: Lots of turbo options, could even come close on factory low mount and that means you save $1k on manifold plus can buy an off the shelf dump pipe rather than something custom.Fuel system, 1500cc injectors, PW surge with twin 460's, twin feed rail, fuel reg. $2500Exhaust $1500Glide and tailshaft probably $8-10kMotor depends on if you build it or not. I think the spool rebuild kit is $1100 or so.If you can build and install the motor yourself then should come close to $15-20k, but as all know budget more because sh*t goes wrong and breaksAlready have a 6boost top mount manifold for it, glide I don't think will be that much (just got one for my burnout car- powerglide, convertor and custom tailshaft for $5000 rated to 1000hp). Motor I'm going to build myself and also do exhaust my self. How much power can the 5 speed manuals hold? Bugger all? 6 speed box if I stayed manual? Link to comment https://www.fordxr6turbo.com/forum/topic/90282-engine-work-for-700rwhp/page/2/#findComment-1537084 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 1d Posted 28/03/15 01:41 AM Share Posted 28/03/15 01:41 AM 5sp good for about 250kw. 6sp are Pretty much unbreakable. Lots of guys pushing 7-800rwhp 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90282-engine-work-for-700rwhp/page/2/#findComment-1537118 Share on other sites More sharing options...
Deanochristo New Member 7 Member For: 10y 28d Posted 31/03/15 05:34 AM Author Share Posted 31/03/15 05:34 AM What breaks in the 5 speeds? A certain gear? Link to comment https://www.fordxr6turbo.com/forum/topic/90282-engine-work-for-700rwhp/page/2/#findComment-1537618 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 1d Posted 31/03/15 11:15 AM Share Posted 31/03/15 11:15 AM Yeah 3rd hates torque Link to comment https://www.fordxr6turbo.com/forum/topic/90282-engine-work-for-700rwhp/page/2/#findComment-1537699 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 30d Gender: Male Location: Perth Posted 01/04/15 12:44 AM Share Posted 01/04/15 12:44 AM 1st,2nd,4th and 5th aren't real flash either 2 Link to comment https://www.fordxr6turbo.com/forum/topic/90282-engine-work-for-700rwhp/page/2/#findComment-1537743 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 30d Gender: Male Location: Perth Posted 01/04/15 01:19 AM Share Posted 01/04/15 01:19 AM *or reverse 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90282-engine-work-for-700rwhp/page/2/#findComment-1537751 Share on other sites More sharing options...
