ndg88 New Member 2 Member For: 13y 4m 2d Posted 25/03/15 12:37 AM Share Posted 25/03/15 12:37 AM Ba xr6t uteHad an issue with the dash cutting out and only fuel level reading, warning lights come on and all gauges cut out. At the same time the ICC? unit cuts out and reads CODE, and radio and a/c cuts out.This normally happenes on start up and has regularly just turned back on mid drive. It happens on average once a week and seems to be random. I've looked over the engine bay and both fuse boxes but all plugs/wires/fuses seem alright. Anyone had this drama or know what the deal is? Link to comment https://www.fordxr6turbo.com/forum/topic/90279-ba-dash-and-icc-int-fault-still-drives-normal/ Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 5m 1d Gender: Male Location: Brisbane Posted 25/03/15 12:55 AM Share Posted 25/03/15 12:55 AM Link to comment https://www.fordxr6turbo.com/forum/topic/90279-ba-dash-and-icc-int-fault-still-drives-normal/#findComment-1536570 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 4m 22d Gender: Male Location: WA, Perth Posted 25/03/15 05:17 AM Share Posted 25/03/15 05:17 AM loose ICC connector??Or the battery 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90279-ba-dash-and-icc-int-fault-still-drives-normal/#findComment-1536616 Share on other sites More sharing options...
Serangan Member 103 Member For: 11y 6m 30d Gender: Male Location: Hobart, Tasmania Posted 27/03/15 11:15 PM Share Posted 27/03/15 11:15 PM Happened to me, turned out to be the ICC connector. The locking mechanism failed on mine and it was jumping loose. Cable tie to hold it together and it hasn't done it since. Link to comment https://www.fordxr6turbo.com/forum/topic/90279-ba-dash-and-icc-int-fault-still-drives-normal/#findComment-1537102 Share on other sites More sharing options...
Wranglerfpr000 New Member 20 Member For: 8y 5m 20d Posted 17/02/17 12:06 AM Share Posted 17/02/17 12:06 AM Howd ya cable tie it mate?....did you take the connector out of the dash and manually insert it into the ICC? Link to comment https://www.fordxr6turbo.com/forum/topic/90279-ba-dash-and-icc-int-fault-still-drives-normal/#findComment-1632043 Share on other sites More sharing options...
