Anyone Running A Flex Tune, Eg Scalable From 98 -> E85
rollex
  • Member For: 10y 5m 4d
I know a lot of the aftermarket ECUs like vipec etc can do this quite easily, can the ford ecu with an SCT do a flex fuel tune using an alcohol sensor in the tank?
Normally they will do 4-5 tunes (E20, E40, E85 etc) and then the ECU will interpolate between the maps depending on the alcohol content.
Curious if anyone here is doing it over the dual tune option and if so what hardware they are using.
Cheers
The ford ecu does not have a flex sensor input to even think about tuning for variable ethanol content
It has a spare analog input I'm pretty sure though?
  • XR50T
  • Member For: 11y 6m 11d
There's a member (gaz084) on the ford forums with a procharged ute (originally an EGAS) that runs a haltech piggyback on his BA ute.
Used to use it for an LPG setup but is now going to use it with an ethanol sensor.
Should be seeing 500 odd rwkw when its done.
