Help Me Guess The Mystery Noise
FiftyOne
  • Member For: 11y 3m 18d
If you just want to check you can just drop the belt off run it for a very short time see of the noise goes away. Haven't tried this on a falcon admittedly but should be ok.
  • Bronze Donating Members
  • Member For: 11y 8m 9d
Na deff not injector tick. It's a defined rattle like a chain bouncing. I've just swapped out the belt & checked the pulleys. The idler on the cover is smooth but probably a little buggered. The arm & tensioner are free. I don't think there's any other things on the arm that could fail?
  • 2 years later...
  • New Member
  • Member For: 13y 4m 4d
Hey FiftyOne, did you ever get to the bottom of this? I have a noise that is like a very gentle rattle when accelerating lightly from 2500-3000rpm. only does it when car has been running for short period. when really hot it goes away or when you hold it in that rev range for about 5-10 seconds it suddenly stops.
