atrovato New Member 3 Member For: 10y 2m 12d Posted 18/03/15 09:38 AM Share Posted 18/03/15 09:38 AM (edited) hey guys, so just picked up my bf tornado zf 6, its all standard, problem im having is when I put it under load LIKE A FAIR BOOT the gearbox seems to be engaging neutral and then drops back in to gear, dash lights come on mainly ABS , then the speedo drops out , have had it on a snap on scanner and come up with U1900 (ABS CAN communication) and U2514 (Missing message), these codes only seem to be popping up in engine, cluster and abs modules but not transmission ,this is happening and all drive types, like normal D, performance and semi auto.. wandering if anyone has had this happen or know of anyone that has had it happen before, any input is much appreciated Edited 18/03/15 09:41 AM by atrovato Link to comment https://www.fordxr6turbo.com/forum/topic/90252-maybe-transmission-fault/ Share on other sites More sharing options...
DD-XR-6T Member 134 Member For: 12y 1m 17d Gender: Male Location: Sydney/Canberra Posted 18/03/15 10:45 AM Share Posted 18/03/15 10:45 AM The common thing in your post appears to be ABS related. Speedo uses abs sensors, Abs fault code, ABS light. I would assume the ZF box would have a feed from them too, happy to be corrected. I'd be trusting the equipment and looking at the ABS sensors. Link to comment https://www.fordxr6turbo.com/forum/topic/90252-maybe-transmission-fault/#findComment-1535460 Share on other sites More sharing options...
spook Donating Members 180 Member For: 17y 1m 9d Gender: Male Posted 18/03/15 11:01 AM Share Posted 18/03/15 11:01 AM Mate I had the exact same sequence of faults with my BF. New coil packs fixed it. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90252-maybe-transmission-fault/#findComment-1535461 Share on other sites More sharing options...
atrovato New Member 3 Member For: 10y 2m 12d Posted 21/03/15 05:27 AM Author Share Posted 21/03/15 05:27 AM wow really coil packs, would never have thought ? ill try what guy above you said and maybe try clean the abs sensors, apparently they can get clogged up etc and its free , will keep posted cheers Link to comment https://www.fordxr6turbo.com/forum/topic/90252-maybe-transmission-fault/#findComment-1535972 Share on other sites More sharing options...
spook Donating Members 180 Member For: 17y 1m 9d Gender: Male Posted 21/03/15 11:15 AM Share Posted 21/03/15 11:15 AM I also cleaned my ABS sensors at first trying to fix it - no go. My guess is that a faulty coil pack was arcing and caused a spike in the CAN Bus. The part that really worried me was the ZF jumping into neutral especially as it would only do it under load (plus the speedo cutting out and ABS lights etc) Since replacing all coil packs over 12 months ago it has not missed a beat. If you have a few K's on the car it's worth replacing them in any case. Link to comment https://www.fordxr6turbo.com/forum/topic/90252-maybe-transmission-fault/#findComment-1536017 Share on other sites More sharing options...
atrovato New Member 3 Member For: 10y 2m 12d Posted 17/01/16 05:55 AM Author Share Posted 17/01/16 05:55 AM okay so after ford having the car and testing it they snaped the input shaft and the transmission had to be replaced , was under warranty for paid the extra for a built one , got the car back from them saying the problem had been fixed and that it was purely the transmission , once again ford has failed at there job , and was still doing it after a 7k bill that was forward onto the car yard I bought the car off and then I took it upon myself as you said I work at autobarn and bought a cheap nasty set of coild and tested them that night and success not one fault so I ran around on them for a few weeks just to make sure it had fixed my problem and I then made ford give me a set of genuine coils , you could see the cracks down the side out 5 of them , all is good now car makes 419rwkw on e85 daily , cheers for your help 4 Link to comment https://www.fordxr6turbo.com/forum/topic/90252-maybe-transmission-fault/#findComment-1577321 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 8m 10d Gender: Male Location: Townsville Posted 19/01/16 01:15 AM Share Posted 19/01/16 01:15 AM Excellent outcome apart from the fck around by Ford. I stand by the moto...If you want it done right, do it yourself!!! Link to comment https://www.fordxr6turbo.com/forum/topic/90252-maybe-transmission-fault/#findComment-1577462 Share on other sites More sharing options...
michaelevans73 New Member 2 Member For: 9y 2m 8d Posted 05/03/16 12:39 AM Share Posted 05/03/16 12:39 AM Hi, I have an FG 2008 xr6 turbo. ZF six speed locks into third gear either in normal or performance mode. Nobody seems to know what it is. I turn the engine off and restart and fault clears for several days sometimes. Took it to Ford in Bayswater Victoria who charged me $168.00 and advised me that they could not fault it. 'Customer to monitor'.....Great. Can anyone out there please tell me what the problem might be please?. Nobody, even Ford cannot tell me.. Oh, the small screen pops up with a graphic of a gear and says 'tansmission fault' with a small triangle containing the number one. Thank You Mike Evans. Link to comment https://www.fordxr6turbo.com/forum/topic/90252-maybe-transmission-fault/#findComment-1581453 Share on other sites More sharing options...
Lennox Member 2,586 Member For: 12y 2m 17d Gender: Male Location: Perth Posted 05/03/16 12:56 AM Share Posted 05/03/16 12:56 AM Sounds like limp mode though mines never done it. Have you modified the car Link to comment https://www.fordxr6turbo.com/forum/topic/90252-maybe-transmission-fault/#findComment-1581454 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 9d Gender: Male Location: Central Coast Posted 05/03/16 08:23 AM Share Posted 05/03/16 08:23 AM Double posting like a maniac Link to comment https://www.fordxr6turbo.com/forum/topic/90252-maybe-transmission-fault/#findComment-1581486 Share on other sites More sharing options...
