Cormo Donating Members 16 Member For: 7y 9m 8d Gender: Male Posted 25/11/17 02:10 AM Share Posted 25/11/17 02:10 AM Hi, Is there anything special about the heater pipe to thermostat housing o-ring due to its exposure to temperature & coolant? If nothing special, what size? Where do people generally buy them, from Ford or aftermarket etc? What type & ID sized hose is required to replace the two short pieces (2" approx.) in the water coolant lines that run to & from he turbo. I just want to make sure I've got the right bits beforehand so I don't get stuck over the weekend. Thanks . . . Link to comment https://www.fordxr6turbo.com/forum/topic/90251-small-coolant-leak/page/2/#findComment-1647601 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 9d Gender: Not Telling Posted 25/11/17 02:55 AM Share Posted 25/11/17 02:55 AM If this is the right bit then I've taken some pics with some measurements and also included a conversion chart from metric to imperial. The bottom picture shows a hard, old farked one compared to the good condition green one. As for the type of hose I just salvage old hose I have lying around for small bits like that but here is some hose info if you are interested. Tl;dr 2 bits of 3/8 hose @ 6 cm and 7 cm The large o-ring has a 19mm ID Nice mine there too by the way Link to comment https://www.fordxr6turbo.com/forum/topic/90251-small-coolant-leak/page/2/#findComment-1647602 Share on other sites More sharing options...
Cormo Donating Members 16 Member For: 7y 9m 8d Gender: Male Posted 25/11/17 04:06 AM Share Posted 25/11/17 04:06 AM Spot on, thanks for all your effort & measurements. Exactly what I was after. Appears as though the hose has to be coolant hose not fuel hose. Link to comment https://www.fordxr6turbo.com/forum/topic/90251-small-coolant-leak/page/2/#findComment-1647605 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 9d Gender: Not Telling Posted 25/11/17 04:19 AM Share Posted 25/11/17 04:19 AM No worries. Fuel hose will work but if you're buying it then get coolant hose. Link to comment https://www.fordxr6turbo.com/forum/topic/90251-small-coolant-leak/page/2/#findComment-1647606 Share on other sites More sharing options...
