Am I Gunna Get There
  • WOT?
  • Moderating Team
  • Member For: 11y 11m 1d
Are you using internet explorer?
Were issues posting pics ages ago - not sure if it's fixed.
Try firefox or chrome and see if it works.
  • Member For: 10y 11m 29d
stuff I got so far (parts sitting there ) process west serge with single 460 ,and a walboro in tank 255 litre fuel pump -mace intake manifold spacer to cut down some heat ($55 of face book )-x force s.steel 4 inch dump and 5 inch cat -xr6 turbo development stage 3 turbo with flapper mod and 12 psi actuator -atomic chain with hardened sprocket-oil pump gears from spool fitted to pump by Jamie .DBA T2 brakes (paid only $280 of face book brand new )front and back with red stuff pads (ordered bendix pads but they got me those ?) BTR build by Dominello for 550 rwkw and a 2800-2900 stall with a Yella Terra flex plate ($300 of face book brand new ) .Nizmo cold air intake with air box and kn filter -PAC valve springs -ARP head studs -
going to fit the exhaust manifold of the fg and run the turbo the same way ,will custom make the cold side piping to suit .will also custom make the hot side to suit the fg intake manifold . have also got the spacer fro atomic to fit the ba throttle to it .still going to run the e boost and 32mm blow of valve from turbosmart .
now for the engine I will let the engine builder decide what to do
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 9m 16d
then you're alright - my instructions are for a windows pc (any manufacturer) and it's also made for dumb curnts, so you're set! :)
  • Like 2
Guest
This topic is now closed to further replies.
