"Captain Retard" Member 1,417 Member For: 10y 9m Gender: Male Location: Shellharbour NSW Posted 28/04/15 11:17 PM Share Posted 28/04/15 11:17 PM I would imagine if the car was upside down then the bores and rocker gear would be drowned in oil.The crankshaft bearings on the other hand, well errrr they might not be so lucky. 1 Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 8m 22d Gender: Male Location: Gold Coast Posted 29/04/15 06:46 AM Share Posted 29/04/15 06:46 AM Not trying to do your head in Gunna but I'm with Jet on this one. From what I've seen thus far, aside from the roller pic, I don't think it's too bad at all.I would have maybe binned the sus roller/s and installed new cams (if required) with your new valve springs and got it running. Checked compression and if all good, away you go. Now that you've gone this far, I'd put oil pump gears in it. If you've already pulled the pants off, remove one cap and check the bearing. If fine, get it to TBRE and get Tony to screw it back together with new pump gears and away you go. Link to comment Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 5d Gender: Male Location: near brisbane Posted 29/04/15 08:01 AM Author Share Posted 29/04/15 08:01 AM have a Atomic chain -bottom timing gear - oil pump gears -arp head studs and pac valve springs . so how about I tear it down and give it a hone and maybe some new rods and pistons -rings and bearings . but how much are the rollers going to set me back ? Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 2d Gender: Male Location: Adelaide Posted 29/04/15 08:09 AM Share Posted 29/04/15 08:09 AM you will seriously win the award for making things the most complicated EVER in a car build 7 Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 2m 13d Gender: Male Location: Brisbane Posted 29/04/15 08:15 AM Share Posted 29/04/15 08:15 AM Lol mate you got the fg donk so you didn't have to build it. If it all checks out get it back together and go!I'd be heeding the above advice. Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 12d Posted 29/04/15 08:46 AM Share Posted 29/04/15 08:46 AM have a Atomic chain -bottom timing gear - oil pump gears -arp head studs and pac valve springs . so how about I tear it down and give it a hone and maybe some new rods and pistons -rings and bearings . but how much are the rollers going to set me back ?Rods yes. Can't just hone it and fit forged pistons. It will need to be bored over.And if you have gone this far you could have used your standard engine. All your keeping is your block and crank. 1 Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 12d Posted 29/04/15 08:47 AM Share Posted 29/04/15 08:47 AM Couldn't you get your rollers out of your current motor? 1 Link to comment Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 5d Gender: Male Location: near brisbane Posted 29/04/15 09:28 AM Author Share Posted 29/04/15 09:28 AM got no idea how the ba rollers would look like after 115,.000 klm ,and they had a few valve bounces at 6700 rpm .Wombat ,I know what you talking about lol. it would have been a simple change over if those rollers would have been fine , but after that I started to look what else might be wrong . I was always going to change the oil pump gears so I thought I might as well do the chain and gear . thought that by fitting a low mileage FG engine I would save some money . as I save on a plenum -turbo housing etc .so what ist he best way of going to fix this problem ,if I send the engine back I can see him not paying me all the money (maybe half ? SO I MIGHT KEEP IT AND ASK HIM FOR A $1000 BACK . was thinking to take it to a machine shop and get them to balance it and fit new bearings and rings if needed .please give me some advise on what might be the best way to approach this . I know I should have just got a engine build as I am a fussy kahnt , just thought that the engine would have been like new without wear and tear . am I just exaggerating about the problems with the engine or am I right about that there is a problem Link to comment Share on other sites More sharing options...
"Captain Retard" Member 1,417 Member For: 10y 9m Gender: Male Location: Shellharbour NSW Posted 29/04/15 09:51 AM Share Posted 29/04/15 09:51 AM FFS GUNNA!SCREW IT BACK TOGETHER AND TUNE THE FARKER.I swear if you go and put new rings ,bearings ,balance etcI'M GOING TO FARKING NECK MYSELF !!!!!!!!!!!!!!!!!! 6 Link to comment Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 11y 8m 7d Gender: Male Location: NOR Perth Posted 29/04/15 09:57 AM Share Posted 29/04/15 09:57 AM ^^^ WHS Link to comment Share on other sites More sharing options...
