sonny628 Member 24 Member For: 14y 6m 27d Posted 08/03/15 07:55 AM Share Posted 08/03/15 07:55 AM Hi guys, I have recently put a built motor that I bought off a forum member a while ago into my 05 xr6t, everything seems fine with it aside from the oil pressure once it starts heating up, it is still running as a stock motor with the stock tune and injectors ect. At a cold start I will see 60psi and it will slowly make its way down to around 20psi and sometimes a little lower as the temp gauge reads about halfway between a quarter and half. I'm using the same oil as I used before "nulon 10w40 fully synthetic" but I never used my oil pressure gauge then. The question that I have is, 1. Is this a normal oil pressure for an xr6t 2. being the fact that this motor has a forged bottom end, billet oil pump gears ect, do I need to run a higher viscosity oil? Link to comment Share on other sites More sharing options...
TomT Spooling Member Donating Members 961 Member For: 13y 4m 4d Gender: Male Location: Blue Mountains, NSW Posted 08/03/15 08:53 AM Share Posted 08/03/15 08:53 AM They are pretty normal pressures for cold start/hot idle. Link to comment Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 12y 4d Gender: Male Location: A big bridge over a river in South Australia Posted 08/03/15 09:04 AM Share Posted 08/03/15 09:04 AM (edited) Exactly what my pressure is mate with same oil. FG though.Sounds fine to me.....nothing to worry about but if you are, I noticed a 'slightly' higher reading when running Castrol Edge Edited 08/03/15 09:05 AM by BenDoCo Link to comment Share on other sites More sharing options...
sonny628 Member 24 Member For: 14y 6m 27d Posted 08/03/15 09:07 AM Author Share Posted 08/03/15 09:07 AM Cheers for that fellas. Link to comment Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 11y 11m 18d Gender: Male Posted 08/03/15 12:04 PM Share Posted 08/03/15 12:04 PM Run the oil the motor is built for clearance wise. Link to comment Share on other sites More sharing options...
Jeremy Member 112 Member For: 16y 11m 28d Gender: Male Location: Perth mindaz Posted 17/05/15 02:36 AM Share Posted 17/05/15 02:36 AM (edited) how much does the oil pressure change from stock -> modded (400rwkw) -> Built (600rwkw)?Has anyone tracked it before or have an idea base don other posts they've seen? Edited 17/05/15 02:36 AM by Jeremy Link to comment Share on other sites More sharing options...
